Differential Pressure Feedback EGR
Old Mar 26, 2004 | 03:36 PM
eaglerivermike's Avatar
eaglerivermike
I have a 2002 Ford explorer, and last week the "service engine soon" light came on. So I plugged in my code reader and it tells me code P1400 which is "Differential Pressure Feedback EGR Cicuit Low Input." The car drives fine, and has 37000 miles so no warranty. Will replacing the EGR or DPFE fix this problem, a new EGR is only $64. Or could it be something else, if so what and is it worth taking it to the dealer?
Old Mar 26, 2004 | 03:42 PM
Bob Ayers's Avatar
Bob Ayers
Get your dealer to run your VIN. Ford has extended the warranty on some DPFE sensors, depending on your VIN.
Old Mar 26, 2004 | 05:53 PM
eaglerivermike
I called and Ford extended the waranty on the escape, but not the explorer. The service manager that I spoke to said that moisture must have gotten into the sensor and the DPFE sensor was probably bad, they sold a replacement kit for $71 which I could probably replace myself. Does that sound reasonable?
Old Mar 26, 2004 | 06:34 PM
Bob Ayers's Avatar
Bob Ayers
That sounds about right, the DPFE sensor for a Ranger is about $75 from my Ford dealer..
Old Mar 26, 2004 | 06:36 PM
c_rossman's Avatar
c_rossman
Most manufactures warranty emissions for 60,000 miles minimum by law.
Old Mar 26, 2004 | 06:46 PM
Bob Ayers's Avatar
Bob Ayers
I questioned Ford about the same thing, when my Ranger DPFE sensor went bad. I was told the DPFE sensor doesn't fall under the emissions warranty!!!
Old Apr 4, 2004 | 10:00 PM
eaglerivermike
Thanks, I think I will try and replace the DPFE sensor and see if the code goes away. Thanks
mike
Old Apr 9, 2004 | 02:44 PM
EpicCowlick's Avatar
EpicCowlick
Ford Part Number
The new part available at Ford dealers is slightly larger than the original. I replaced the old one with a new one and my code has not come back. The new part at the dealer is cheaper too, $29. The part number is: 4U7Z 9J460 AA. Good luck. A very easy (and cheap now) fix. No tools needed.
Old Apr 9, 2004 | 03:09 PM
eaglerivermike
I replaced the DPFE 2 days ago and the code has not come back! The parts guy told me to look for moisture in the old DPFE and there was water which is supposed to be a partial cause of the failure. Thanks for all the help.
Old May 10, 2004 | 05:29 PM
QuinnMassage's Avatar
QuinnMassage
Is it easy to install the DPFE sensor?
Old May 10, 2004 | 10:33 PM
eaglerivermike
so easy, took less than 60 seconds, just a quick plug. the part cost $34.
danboy282
Bronco II
Feb 29, 2012 06:35 PM
DJdemon6696
May 8, 2007 07:57 PM
tstrickland
1983 - 2012 Ranger & B-Series
Aug 24, 2001 09:35 PM
doug
Aug 11, 1999 10:45 PM
