Seized headlight switch
Old May 27, 2009 | 01:40 PM
zenmaster's Avatar
zenmaster
Hello again,
The headlight shaft/**** is stuck in the "off" position, and I can't seem to get it to move. The truck sat for 15 years, so it's probably stuck due to corrosion. I sprayed it with liquid wrench, but it's still stuck. I can't get the shaft to move at all. I'm afraid if I pull any harder on it, I'll break it. It does turn left to right. I know I'll probably have to replace it, but I need to remove it first. I know about the button on the switch to remove the shaft, but that works only after you get it to the "on" position. Any help is appreciated.
This is a 1967 M100 pickup, vin: F10YCA47463
Thanks,
John
CurtisNova
Feb 24, 2014 10:32 PM
clemensfield
Jun 20, 2013 11:27 PM
paddler
Dec 29, 2012 10:35 PM
cacowgirl410
New Member Introductions
Feb 16, 2007 03:23 PM
jeffh
Nov 22, 2001 08:08 AM
