2003 Ford Explorer XLT V8
Old May 27, 2009 | 12:37 PM
marine232009's Avatar
marine232009
I have a 2003 Ford Explorer XLT V8 4X2 with 43000 miles on it. The service engine light is on and does not go away. I have changed the air filter the oil. what else should i do? need help.
Also when i press hard on the gas the ABS light comes on what does that mean? THanks
Old May 27, 2009 | 02:15 PM
liftnw8z's Avatar
liftnw8z
Have you had the opportunity to hook up a code reader and see what codes the computer is putting out? That will give you a better indication as to what may be wrong. It's going to be hard for any of us to know what the problem is or how to help you out without knowing what the code(s) are also. SEL's can be from any number of things.
Old May 27, 2009 | 02:22 PM
marine232009
2003 Ford explorer XLT V8
thanks i should have said it said something like exhaust or something in that point. But the ABS problem i could find out anything on that. thanks though
2003 ford explorer
New Member Introductions
Sep 26, 2014 09:42 AM
real_texan
Jan 6, 2013 11:05 AM
yg101
Oct 13, 2012 12:05 PM
Ford7269
19
Aug 6, 2010 08:12 PM
osheam
Sep 9, 2007 12:23 AM
