Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
99 svt f150 lightning codes
Old 04-11-2009, 06:38 PM
oss150svt's Avatar
oss150svt
oss150svt is offline
any one familiar with these codes? my 99 lightning has been cutting off ,hesitating and missing . we put a scanner on it and these are the codes that came up
po 1747 - system bank
po 0354 coil d primary
secondary circuit
trouble code
po 9171 - 2 lean bank 1
I need to change the coil but is it the front or back ? driver or passenger?
Old 04-12-2009, 12:51 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
secondary circuit
trouble code
Diagnostic Trouble Code (DTC) P1747 is a tranny code.
P1747 - EPC Solenoid Short Circuit:
"The electronic pressure control solenoid is a variable force solenoid. The variable-force type solenoid is an electro hydraulic actuator combining a solenoid and a regulating valve. It supplies electronic pressure control that regulates transmission line pressure and line modulator pressure. This is done by producing resisting forces to the main regulator and the line modulator circuits. These two pressures control clutch application pressures."
DTC P0354 means your number 4 cylinder Coil On Plug (COP) is bad. The number 4 cylinder is on the passenger side, last one in the back, closest to the firewall.
To confirm it's truly bad, swap it with the COP on cylinder number 1. That would be on the same side (passenger), but it's the forward-most cylinder, closest to the radiator. Drive it for a bit (couple days) and then scan it for codes. If that coil is truly the culprit, the P0354 code should be gone and you should now have a P0351 code.
For DTC P9171, I think you mean 0171, which would mean bank one is running lean. The passenger side is bank one, and it points to a possible vacuum leak. Check all of your vacuum lines, making sure the hoses aren't cracked anywhere, and all of the hose fittings are in good shape.
Stewart
Old 04-12-2009, 08:12 AM
oss150svt's Avatar
oss150svt
Trouble codes 99 svt lightning
STEWART........THANK YOU. I had this problem for the last few weeks and tried everything but it as you read it didnt work. THANK YOU.
Old 04-12-2009, 05:47 PM
Stewart_H's Avatar
Stewart_H
You are welcome. I hope the info helps you out.
Stewart
Old 05-10-2009, 11:50 AM
oss150svt's Avatar
oss150svt
you
STEW...............Im still having a problem. When the supercharger kickss in there is a miss then the supercharger kicks in or the engine stalls. NO CHECK ENGINE LIGHT. I scan the engine no codes. But one the mechanics I work did something crazy with the scanner and came up with a code that said reset your computer. I think the code wa P065.
Old 05-10-2009, 05:32 PM
Stewart_H's Avatar
Stewart_H
DTC P065 - Air Assisted Injector Control Range/Performance.
I have no experience with that code, sorry bro.
Also, I'm not sure I understand what you mean when you describe the supercharger as "kicking in". I'm a bit confused because the SC is always working when the engine is on. It doesn't "idle" until the pedal is whomped on, it's always turning and pushing air.
With the eingine stalling though, it can be narrowed down to three possibilities. Air, fuel, or spark. One of those, if not more, is your culprit, or something else down the line that is affecting one of those three items, like a bad PCM, bad sensor or wiring in the harness, bad fuel pump (or both pumps), bad fuel pump relay, something...
Stewart
Old 05-10-2009, 10:29 PM
oss150svt's Avatar
oss150svt
ok.............I'll check all the possibilities you mentioned. What I mean by kicking in is when the supercharger gives the engine boost. I hope I said it correctly. I'll check the code , I could be wrong. THANKS again.
Old 11-14-2010, 11:44 AM
bowtiebender's Avatar
bowtiebender
bowtiebender is offline
Exclamation 2001 Lightning with ticking noise
I have a 2001 Lightning SVT, with codes P0402 and code P0171. I ran a code check after engine started making a ticking noise in time with engine,especially when at idle or park. I have had no engine problems it still runs like new. The ticking noise is driving me crazy, but you dont hear it as long as gas pedal is applied. If anyone knows about this please inform me. Thanks.
Old 11-14-2010, 10:28 PM
Stewart_H's Avatar
Stewart_H
I answered you in your thread.
Stewart
Nik Afan
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-30-2017 07:17 PM
mblayton
Ford Truck Parts for Sale
12-03-2016 09:36 PM
mblayton
11-11-2016 11:09 AM
Justin Moons Simon
1997 - 2003 F150
02-03-2016 11:26 AM
Gond8048
11-18-2002 02:19 AM
Quick Reply: 99 svt f150 lightning codes
