E40D TCC
Old May 30, 2002 | 10:03 AM
mu5tanggt's Avatar
mu5tanggt
E40D TCC
[updated:LAST EDITED ON 30-May-02 AT 11:04 AM (EST)]This is my first question to the board. I have a 92
Bronco 5.8 E4OD with 100k, trans history is unknown.
My TCC locks up, it seems to be slipping but I have no shudder,
under light/medium load I will see a 100-150 RPM rise on the tach at highway speeds. I'm getting a code 628, pan has been down, no chunks,
fluid is red and clear. I've heard there is a programed slip but this seems excessive. Am I heading towards destruction, everything else with the trans seems fine.
Thanks in advance
Old May 30, 2002 | 10:22 AM
jimandmandy's Avatar
jimandmandy
Post E40D TCC
You'll know it's shot when the trans starts shifting real hard. The computer will increase the oil pressure to maximum. If you haven't already, drain the converter, then drop the pan to do a complete fluid change. That might be all you need.
Jim
Old May 30, 2002 | 10:32 AM
mu5tanggt's Avatar
mu5tanggt
E40D TCC
Trans fluid has been completly changed, was having problems with the trans not shifting, shifting hard but this was a bad electrical connection at the solenoid pack, local trans shop that has been lending free advice said run it they couldn't find anything wrong. Trans has been shifting fine since then.
Gary
Old May 30, 2002 | 02:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
E40D TCC
There is no programmed slip in the E4OD. The AODE and 4R70W used some, but it was less than 50 RPM.
It sounds like the torque converter clutch has failed. You probably need a new torque converter.
Mark
Old May 30, 2002 | 02:56 PM
Mark Kovalsky
E40D TCC
