Offroad & 4x4
e4od frustration
Old May 26, 2009 | 03:19 PM
tpw35's Avatar
tpw35
e4od frustration
I have a 93 bronco. I just swapped the e4od in it with one out of a wrecked f-150 4x4 that was supposed to be good when it was pulled. After I installed it, it wasnt shifting correctly I cleaned the electrical connections and it seemed to fix the problem, I drove it around town a few times and it shifted smooth, I took it on the interstate today and it started making a whining noise like when you run over the ripple strips, I backed of the gas and it quit for a few mins, the started again, I got off at the next exit and when I stopped I felt a clunk, I drove through town the rest of the way, The whining sound never came back but each timed I stopped the clunk would happen, When I finally got where I was going it started leaking fluid out of the front?
Old May 27, 2009 | 01:09 PM
TheTinian's Avatar
TheTinian
Keyword right there. Sounds like you got some issues goin on there....
Are you sure everything is tight?
Old May 27, 2009 | 01:57 PM
75F350's Avatar
75F350
Did the bellhousing come loose?
Ive never had any inclination to install a used auto trans. I hate doing things twice.
The Harvester
Feb 1, 2014 06:00 PM
AbandonedBronco
1978 - 1996 Big Bronco
Jan 7, 2013 10:32 AM
coalmanjhj
Sep 18, 2011 07:32 PM
tfarvour
2004 - 2008 F150
Nov 10, 2009 07:37 PM
