Sponsored by: Real Truck
Electronic Climate Control Issues
Old May 26, 2009 | 01:05 PM
kdawg1989's Avatar
kdawg1989
Hi Everyone,
I have a 2005 F350 with a 6.0 PSD and it has the electronic climate control option but recently what has happened is I can control the temp. of the air no problem and and I can control what vents it blows out of but no matter what speed I set the fan on it always blows on high and if I push the off button rather than switching the fan off it switches to defrost and blows on full speed. And I have already switched out the climate control module with one from a truck that is working correctly and that didn't make a difference so I don't think that the problem is with the control module. Any help is greatly appreciated thanks in advance for your help.
Old Jun 9, 2009 | 12:02 PM
summitseeker's Avatar
summitseeker
I have the EXACT same problem. I tried disconnecting the batteries to see if it would reset itself but does not. I also drive an 05 6.0. Would love to get this thing fixed!
Old Jun 9, 2009 | 12:46 PM
kdawg1989's Avatar
kdawg1989
Well luckily for you I have solved it. If you open your hood and look on the passenger side of the engine compartment you will see the A/C condenser and almost right behind it there is a black box that has a part number on it and it has a plug the plugs into the bottom of the box and it is mounted on what I believe is the vacuum pump. If you have a hard time finding which box it is let me know and I can post a picture of it later tonight. But it is that controller box that is bad and there is 2 options, you can replace that box which is somewhere are $50 or you can repair that box here is a link that kind of explains how to fix it. https://www.ford-trucks.com/forums/5...wer-issue.html
Good luck to ya, Let me know how it goes
Old Jun 9, 2009 | 01:38 PM
summitseeker
Thanks for the response! I also found another thread right after my original post that found solution but only to replace it and not fix the diode. I called my local dealer and they wanted $95.00 for the 3CH-19E624-AA Blower Motor Speed Controller.
A guy posted a link to this site https://www.trademotion.com/memberservices/index.cfm
which has the same unit for $12.95. For that price....I think I will just buy it and do the quick swap.
Old Jun 9, 2009 | 01:43 PM
kdawg1989's Avatar
kdawg1989
Can you post a link directly to the part the is only $13?
Old Jun 9, 2009 | 04:56 PM
summitseeker
https://www.ford-trucks.com/forums/8...f-of-high.html
The link is at in here at the bottom.
Old Jun 22, 2009 | 03:49 PM
summitseeker
So I got this part in and it did not work as it was not for the actual climate control.
I have since purchased the blower motor controller part number (revised) 6C3Z-19E624-AA and immediately fixed the problem. Cost me $111.34 with tax but the fan control is operational again.
Old Jul 9, 2009 | 09:54 AM
Drags's Avatar
Drags
Thank You to FTE!!!! I have an 06 CC Dually,F350 Lariet 6.0 that began to give me the same problem on tuesday morning 7/7/09. Stealer couldn't help me until next week,stating it would take a few days to fix. Low and behold FTE website and your expierience! I called another dealer who could get me the correct part # in 1/2 a day for $54.00! Picked up the part installed it in about 45 minutes, Problem solved! Thanks again! p.s. mY 3/36 WARRANTY EXPIRED ONE DAY PRIOR TO ISSUE REARING IT'S UGLY HEAD! gOOD LUCK HUH?? lmao!
Old Apr 26, 2012 | 05:40 PM
Clinton Hernandez's Avatar
Clinton Hernandez
t
climate conrol does not open gate to differant vent what could be the problem
ghunt
Jul 14, 2020 09:07 PM
bwylie
Apr 30, 2016 12:22 AM
5.0 Heaven
Jun 24, 2013 06:49 AM
bfaulkner
1997 - 2003 F150
Jan 17, 2011 12:39 PM
