3 on the Tree Shifting problem
Old May 30, 2009 | 05:21 PM
oldtexasdog's Avatar
oldtexasdog
Thanks for the advice. I had my plasma torch and MIG in handWasnt going to touch box just do a fill in on frame then re-drill 1/2 in holes in same matching pattern on box with box alinged to steering column. Not a good idea hea?What is this you speak of alining with a pin? I must admit I have never heard of it on a manual tranny.
Old May 30, 2009 | 06:31 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
There is a small bracket on the end of your column ,a small pin 3/16 will slide though the
bracket and though the (Column Linkage Levers ) , First Loosen the Linkage on you trans
Make sure both trans levers are in( Neutral ) ,with the 3/16 pin//or drill bit push though the
( BRACKET and THOUGH the HOLE ) in the (Column shift levers) now crawl under and
Tightened the ( NUTS on your trans lever linkage !
Wally Womack
Old May 30, 2009 | 06:53 PM
Pro-Street/StateTK
Click it
Click it
The pic is of my 65 and I have a fountain pen ink tube just so you can see the bracket ,in this pic the pen is not though the levers because they
would not ( MOVE ) my truck is Auto now used to be manual !
Wally Womack
Last edited by Pro-Street/StateTK; May 30, 2009 at 07:02 PM. Reason: adding pics and trying to help
Old May 30, 2009 | 10:17 PM
oldtexasdog
WOW never seen this before! Everything on mine still moves so I will check this out. Thanks
Old May 30, 2009 | 10:18 PM
oldtexasdog
I just love it when someone can teach an old dog new tricks don't you
Old May 30, 2009 | 11:28 PM
oldtexasdog
Woops lets move foward. I have another post on asking how to remove the steering column. Sorry. Delete this one please. My Dads going to be driving it so no comprimise...it has to be done right! I am ashamed I was going to the Dark Side.
KAT_Ayanami
Mar 8, 2022 06:04 PM
Mav'_BlueF100
Feb 13, 2016 11:47 AM
Dflynn926
Aug 10, 2015 09:21 PM
DieselBurner153
Mar 26, 2013 12:18 AM
Argess
Apr 20, 2011 01:35 PM
