Very Hard Starting
Old May 26, 2009 | 06:34 AM
sealer700's Avatar
sealer700
Very Hard Starting
06 6.0 stock 48000 miles. The other day it started. warm or cold,cold worse, go to start, cycle glow plugs, turn and turn and turn. I am starting to have to cycle glow plugg 2 or 3 times to strt even if engine warm???? please help. Thanks
Old May 26, 2009 | 07:02 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I think the first thing you should do is load test the batteries. Most auto parts chains will do this for no charge.
Old May 26, 2009 | 09:37 AM
sealer700's Avatar
sealer700
It turns over great just wont start until 2nd or 3rd time
Old May 26, 2009 | 10:48 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Are the batteries still the originals? If yes, I would still have them load-tested!! We understand they turn over the engine, they just may not turn it FAST enough.
Old May 26, 2009 | 10:42 PM
riggz's Avatar
riggz
had any voltage issues recently? could be a failing FICM.
Old May 27, 2009 | 04:08 PM
96psdkris's Avatar
96psdkris
Like everyone has said.. check the batteries. I have an 06 and one of my batteries went bad at about 60,000 and it took alot to start it. Changed out the battery and it ran fine for a few months. It started to crank for a long time again and it just wouldnt start. Just got a call from the dealership and it had a fitting on the back of the engine that was allowing air in the fuel system.
Old May 27, 2009 | 04:48 PM
bismic's Avatar
bismic
If you wait until your batteries are so bad that it doesn't crank well, you may be causing early failure of your FICM.
