wont start
Old May 25, 2009 | 10:11 PM
grantbvfd's Avatar
grantbvfd
wont start
Having and issue with a 07 6.0 liter. It has 70k miles on it and the other day it started running a little rough at idle. Jumping from 600 to 900 rpms. I got to where i was going and unloaded some bags and went to move it and it wont start. it will turn over and sounds normal for the first revolution but then it sounds as if it wants to run but rpms stay real low around 150 and dies.
I changed fuel filters the today thinking it was a bad tank of fuel. It started right today and i left for home. I stopped for a bite to eat and came out and tried to start it and it did the same thing wouldn't start. no check engine light though. HELP!
Old May 25, 2009 | 10:40 PM
william_04_x's Avatar
william_04_x
sounds like a high pressure oil leak or a bad ICP sensor...it's worth the cost to have it diagnosed by a tech..
if it's just a sensor that's bad, you can easily do that..if it's a HPO leak under a valve cover, you may want to have them find and repair it..
bubba_3711
Oct 26, 2014 11:57 AM
Diesel 724
24
Nov 25, 2013 12:59 AM
dpm1057
Sep 29, 2008 12:09 PM
ccp
16
Dec 13, 2007 09:29 AM
Pit_Squid
Nov 6, 2005 04:31 PM
