dead need help asap
Old Dec 11, 2007 | 10:39 PM
ccp's Avatar
ccp
dead need help asap
i was driving and my truck started to sound rough and the rpms dropped and it died cps is fine it doesnt seem like its getting fuel it started and sounded rough on starting fluid.
Old Dec 11, 2007 | 11:45 PM
Hiflyer746's Avatar
Hiflyer746
Two things i would check. . . one is all fuses. . . number two is the number 30 fuse on the inside of the truck. It controls the fuel heater and also the PCM relay. The fuel heaters have been known to blow them out. So if its blown out you may have to replace the fuel heater to keep it from happening. More symptoms would be nice. Does the tach come up? do you get a WTS light? Does the oil pressure build? If the tach moves, you don't get a WTS light and the oil pressure i think doesn't build. . . its probably a 30 fuse. What year truck is it? Another idea is it could be and IDM. They have been known to give problems in the past. Hope this helps.
TIm
Old Dec 11, 2007 | 11:49 PM
countrycar's Avatar
countrycar
Don't use starting fluid to start your truck. Use WD-40 or something close to that. SF is way to hot for the Diesel's High Compression, it can blow a headgasket, or a whole in a pistion etc. Well lets start with the obvious stuff first. The fuel fliter. Have you changed it lately of inspected it along with the fuel bowl too, for sediment. Are you able to hear your fuel pump running. You should hear a huummmm coming from the pump. Let's start there. Let me know what yah find if anything. Country
Old Dec 12, 2007 | 12:00 AM
Hiflyer746's Avatar
Hiflyer746
good idea start simple first. I think with my fuel filter experiences. . . they would run rough for a while. . . die. . . usually start again, run rough, die. and eventually not run anymore. But if it was really quick rough and die. . . and you're sure its not a fuel delievery to the injectors problem. . . then look around where I told you too. Let us know. Many of us work some pretty late hours on here. I still havn't gotten that overtime check yet. . .
Tim
I see this is your first post. . . sorry it couldn't be on better terms but you couldn't have found a better place. Enjoy your stay and hopefully you make that an extended stay
Old Dec 12, 2007 | 12:58 AM
jhand124's Avatar
jhand124
I second the fuel filter, if it was #30 fuse you wouldn't see the WTS light. Welcome to FTE.
Old Dec 12, 2007 | 07:14 AM
670johndeere's Avatar
670johndeere
I agree with the #30 fuse check. I just had this happen to me this weekend. Truck acted like it was running out of fuel and died, wouldn't start back up. Checked all fuses and wallaaa. #30 was blown. Good Luck and welcome to the best site to learn how to work on our trucks.
Old Dec 12, 2007 | 07:17 AM
zx250's Avatar
zx250
Of the next Riffraff East
Welcome to the site, hope you find the help you ask for. Other than the suggestions already giving, One question for you, how do you know your CPS is good? Other obvious things to check that could cause your problems, engine oil OK, last fillup WAS diesel and not gas, fuel tank does have fuel? And like stated, don't use starter fluid if at all possible, if you must, use as little as possible.
Old Dec 12, 2007 | 09:45 AM
countrycar's Avatar
countrycar
Tim, great post.. Wow alot of info. I continue to watch and learn. Thanks to all of you for some great ideas and making the newcomers feel welcome. I love this place. CCP welcome to you as well. Not sure if you noticed, but you can't go wrong here with a great bunch of guys like this. Country
Old Dec 13, 2007 | 12:05 AM
ccp's Avatar
ccp
and the winner is engine oil......i was busy with finals so my brother took it to have the oil changes at walmart cause it needed done they filled it a quart below the fill line on the stick so yea im pretty pissed but its alright now. just a reminder if you dont do it yourself stuff can get screwed up.....never again at walmart...never again
Old Dec 13, 2007 | 12:07 AM
ccp's Avatar
ccp
engine oil was my first thought waking up this morning....it was pretty funny
Old Dec 13, 2007 | 12:08 AM
twags6's Avatar
twags6
its nice knowing that if the oil does get low on our trucks, they'll shut off before it runs low enough to do major damage
Old Dec 13, 2007 | 12:09 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Thanks for posting back, and welcome to FTE. Glad it is running now.
Old Dec 13, 2007 | 12:12 AM
ccp's Avatar
ccp
thanks everyone for the input now i need to fix the trans and im good it doesnt shift til it gets to about 20mph and then i let off and get back on it and it shifts and then i cant romp it or it just blows out of gear its an auto but i got a dp chip but like i say it just comes out of gear if i romp it and then i let off it makes a bad clunk and then its fine to get up to speed
Old Dec 13, 2007 | 12:14 AM
Hiflyer746's Avatar
Hiflyer746
Interesting. . I've ran mine two gallons low and it still ran before. That was a couple miles that I lost that two gallons too. most of you heard about that
TIm
Old Dec 13, 2007 | 04:27 AM
Alpine6's Avatar
Alpine6
Is the fluid burnt? Sounds like it's time to start looking for a transmission. BTS (Brian's Truck Shop). It's the last transmission that'll go into your truck.
