Overfilled auto tranny leaking fluid
Old May 29, 2002 | 06:39 AM
TallPaul's Avatar
TallPaul
Ever since my last auto tranny fluid change in the Aerostar 3.0 it has been slowly leaking. Not wanting to hassle with taking it back in I tighetened the pan nuts which were not all that snug (and I did not over do it), but seems to be leaking from above, though not the seals (I don't think). Tranny runs fine, but fluid level seems a good 1 to 1.5 quarts high on dip stick. Is this OK if it is blowing out the vent or am I building high pressures and ultimately going to blow out a seal. Have driven about 3000 miles this way.
Old May 29, 2002 | 10:30 AM
jim henderson's Avatar
jim henderson
Assuming that you are following the procedure for measuring fluid level, being high 1.5 qts is probably risky. You should probably remove the excess. You could use a siphon or if there is a drain plug you might try that but it can be messy.
Excess fluid will possibly cause foaming or blow out the tube or vents.
Good Luck,
Jim Henderson
Old May 29, 2002 | 01:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Excess fluid will cause foaming. Foamed oil does not lubricate well, which can cause a transmission failure!
If you remove a cooler line and start the engine it will pump out fluid. Stop when you get a quart and a half.
Mark
Old May 29, 2002 | 06:42 PM
Syzle's Avatar
Syzle
lol, mine was overfilled, and I did this, and picked the wrong line, and instead of spraying from the line into the bucket it sprayed out of the radiator, lol, I am a goof, :P
Old May 30, 2002 | 12:28 PM
TallPaul's Avatar
TallPaul
Thanks all. I am going to check that level again and then probably try the siphon method first. If I remove a cooler tube it probably will leak when I re-hook it.
BYW, Today I found a couple Tranny shops with FAQs that said overfilling won't hurt unless foaming causes it to malfunction and that it won't blow out seals. Mine functions fine. Still, seems good to remove most of the excess.
Old Jun 4, 2002 | 11:26 AM
TallPaul's Avatar
TallPaul
Syphoned off 1.5 qts. Level is now fine and don't see anymore leaking. Thanks.
Old Jun 4, 2002 | 08:52 PM
FordMasterTech's Avatar
FordMasterTech
MilllerTime
Aerostar
Jul 14, 2014 06:32 PM
miguel2112
Aerostar
Jun 6, 2009 06:57 PM
biggieou
1983 - 2012 Ranger & B-Series
Oct 19, 2004 09:44 PM
gs_jim
Aerostar
Aug 20, 2004 01:13 PM
fordmando
Aerostar
May 13, 2000 08:48 PM
