Speedometer= OK, Odometer= NOT Ok
Old 05-25-2009, 04:47 PM
Thunder Road's Avatar
Thunder Road
Thunder Road is offline
1998 F150
271K+ miles...filled up the tank last week and today noticed that the trip odometer was still set to zero (I reset it at every fillup) AND the odometer itself is not moving.
Speedo works fine....but...
Anyone had the same deal and know how to fix it?...or maybe just know how to fix it?
TIA
Old 05-25-2009, 07:11 PM
n5926g's Avatar
n5926g
n5926g is offline
Havent had my cluster out in awhile,but I can tell you that the SPEEDO is Electrical,which means the odometer should be as well.If youre brave you can pull the cluster out,and take it apart.It could be anything from a frozen up Odometer control motor,to broken gears.
My advice(since its showing that kind of miles anyway) would be to find a Salvage Yard cluster and just replace the one you have.
Chances of fixing yours even if you do get apart,are slim unless somethings just come loose.
Old 05-26-2009, 06:05 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
Tried pushing the button again? My 97 has done that a couple of times .. pushed the button and it started working
Old 05-26-2009, 06:15 PM
Thunder Road
Actually I have Ron..but whereas before, I could feel it resetting, now I don't feel anything. As if it's not engaging.
Thanks for the idea, tho...
Old 05-26-2009, 06:22 PM
n5926g's Avatar
n5926g
n5926g is offline
This may be a good thing....If you cant feel it resetting the tumblers,its a probable sign that its mechanical.Taking the cluster apart carefully may expose a loose retaining clip on the assembly,or at least indicate whats broken.....
Just be sure that you have a clean workbench to use,and plenty of light....
Old 05-27-2009, 04:00 PM
Thunder Road
NEVERMIND - God fixed it!!!
I was driving around this am and just happenend to look down and the thing is rolling over just fine. WOOO-HOOO!!!
I only 'lost' about 100 miles...I'm not gonna tell anybody...hahaha
AND, I ain't touching the trip OD EVER AGAIN!!!
Thanks ya'll!
Old 05-29-2009, 08:29 AM
MikeD1980's Avatar
MikeD1980
MikeD1980 is offline
oh man. I was hoping for a fix. mine stopped about 5 yrs ago at 70,999. when I push the trip reset, the 0's move a little. has anyone ever taken one of these aprt and actually fixed it?
fredo181
1997 - 2003 F150
08-19-2013 11:15 PM
Big-Red-89
1997 - 2003 F150
07-03-2012 09:41 PM
jojo saw
04-21-2011 05:46 PM
johnny1217
13
02-05-2010 08:55 AM
ford390gashog
1997-2006 Expedition & Navigator
01-15-2005 06:39 PM
Quick Reply: Speedometer= OK, Odometer= NOT Ok
