Speedometer= OK, Odometer= NOT Ok
1998 F150
271K+ miles...filled up the tank last week and today noticed that the trip odometer was still set to zero (I reset it at every fillup) AND the odometer itself is not moving. Speedo works fine....but... Anyone had the same deal and know how to fix it?...or maybe just know how to fix it? TIA |
Havent had my cluster out in awhile,but I can tell you that the SPEEDO is Electrical,which means the odometer should be as well.If youre brave you can pull the cluster out,and take it apart.It could be anything from a frozen up Odometer control motor,to broken gears.
My advice(since its showing that kind of miles anyway) would be to find a Salvage Yard cluster and just replace the one you have. Chances of fixing yours even if you do get apart,are slim unless somethings just come loose.:-X25 |
Tried pushing the button again? My 97 has done that a couple of times .. pushed the button and it started working
Actually I have Ron..but whereas before, I could feel it resetting, now I don't feel anything. As if it's not engaging.
Thanks for the idea, tho... |
This may be a good thing....If you cant feel it resetting the tumblers,its a probable sign that its mechanical.Taking the cluster apart carefully may expose a loose retaining clip on the assembly,or at least indicate whats broken.....:-X25
Just be sure that you have a clean workbench to use,and plenty of light....:-jammin |
NEVERMIND - God fixed it!!!
I was driving around this am and just happenend to look down and the thing is rolling over just fine. WOOO-HOOO!!! I only 'lost' about 100 miles...I'm not gonna tell anybody...hahaha AND, I ain't touching the trip OD EVER AGAIN!!! Thanks ya'll! |
oh man. I was hoping for a fix. mine stopped about 5 yrs ago at 70,999. when I push the trip reset, the 0's move a little. has anyone ever taken one of these aprt and actually fixed it?
