NP435 Clutch Help Needed
Old Jun 13, 2002 | 08:50 PM
AFD301's Avatar
AFD301
Had my 302 out for repairs. Re-installed and found that I could not move the clutch fork to reinstall the pushrod from the linkage. So I removed the motor ..again. Pulled the cluch..seemed fine to my novice eyes. Questions are.. What am I doing wrong? What should I check / look for? and how hard should the clutch fingers be to depress? I am thinking it is a cluch pressure plate problem. I can not depress the fingers very much..Did I incorectly reinstall the clutch....Help me please. Needless to say it hasn't been a good evening. It is a Luk clutch, I beleive a NP435 tran.
Thanks..... Jeff
Old Jun 14, 2002 | 03:07 AM
karljay's Avatar
karljay
> Thanks..... Jeff
You'd have to be VERY stong to move those clutch fingers. The throw-out bearing (release bearing) should slide on the shaft with ease (a shot of grease is good) Your connecting arm should go on the bearing and the bearing should NOT TOUCH the clutch fingers.
The release bearing should ride just behind the clutch fingers without touching them. About 1/8" at least.
If this is a new cluth, it might be the wrong one or may have adjustments for the fingers. I think the three finger style clutch has adjustment bolts on them but I could be wrong.
If this is a new clutch, I'd adjust the push rod down and try again because you usually have to re-adjust it each time you re-install a clutch. If you don't have an adjustable rod, you can get them from Napa, but I haven't seen one that's not adjustable.
Make sure the connecting arm is setup properly, it should be on a pivit (good idea to grease it) then should have clips or slots on the release bearing. You might have had the fork behind the bearing instead of on the bearing.
Make sure the bearing is not bound up on something and moves freely.
Old Jun 14, 2002 | 07:55 AM
Mech 1990's Avatar
Mech 1990
JackWStafford
Nov 28, 2016 12:22 PM
Kyle Wood
Oct 19, 2016 11:28 PM
bluegoose95401
Aug 19, 2014 08:46 PM
ss27gogeta
18
Jun 25, 2014 12:44 PM
ROKRAWL
1966 - 1977 Early Broncos
Nov 18, 2003 12:07 PM
