i'm probably going to put a leveling kit in my 05, so to really level it out, i'm gonna add an f350 4" block in the rear. i'm getting them direct from ford because we have an account with them. when we called up to get a price, they asked me for the vin#, which i obviously didn't have, because they said 3 different types of blocks are listed. How can they be different?
Some are flat, and some are angled due to the length of the truck. A regular cab short bed would need angled blocks as opposed to a crew cab long bed which would use flat.
From what I've gathered for a How-To I wrote a while back:
If you have one of the following:
Crew Cab Short Bed (156" Wheelbase)
Super Cab Long Bed (158" Wheelbase)
Crew Cab Long Bed (172" Wheelbase)
Then use these part #s:
Blocks: F81Z559A x 2
U-Bolts: N803770S436 x 4
Nuts: N620485S441 x 8 (You can reuse the old nuts if you wish.)
Super Cab Short Bed (142" Wheelbase)
Regular Cab Long Bed (137" Wheelbase)
Left Tapered Block: F81Z5598FA x 1
Right Tapered Block: F81Z5598GA x 1
U-bolts: 5C3Z5705AA x 4
If you want to shim the drive shaft:
3 1/4" Shims: EOTZ4A209A x 1 (Comes with 3 1/4" shims. If you use more than 1 shim, you will need longer bolts. Most people only use 1 shim.)
You should shim the driveshaft and also add a track bar drop bracket. Check out Readylift for there complete leveling kits. They have the drop bracket/carrier shim/bump extensions as well as the rear block kits.
