Leveling blocks or springs..?
Old Jun 9, 2014 | 11:19 PM
1993_f350_2013's Avatar
1993_f350_2013
Howdy all I have a 1995 f150 4x4 and was wanting to level it out cause I don't use it to tow often at all and It has a little too much rake for my liking. So with that being said how would y'all suggest I go about doin it..? A 2 inch aluminum block or get moog CC844 springs? I know with either way I'll have to get different camber bushings but I'm not too sure which ones I'll exactly need so if anyone could chime in on that, that would be a great help!
Also I already have 33 12.5 15 tires on factory chrome wheels that rub at full lock but i think it's the backspacing on them so I don't think the level will help much with that.
Thanks guys!
Tye
Old Jun 10, 2014 | 12:55 AM
GoinBoarding's Avatar
GoinBoarding
Springs aren't expensive:
Robot Check Robot Check
Then use:
These gave my truck 1.25" lift, but I have a supercab with 5.8 & E4OD, and a few accessories hanging off the front end.
Old Jun 10, 2014 | 11:08 AM
1993_f350_2013
Here's the blocks I was lookin at http://m.ebay.com/itm/121092820190?nav=SEARCH
Old Jun 10, 2014 | 11:13 AM
W1d0wmak3r's Avatar
W1d0wmak3r
Thanks guys!
Tye
I have the same exact setup including tire size. I have a 3" body lift though. I had the same question. I just want to bring the front up to level with the rear.
Old Jun 10, 2014 | 11:16 AM
W1d0wmak3r's Avatar
W1d0wmak3r
Robot Check
Then use: Robot Check
Looks like exactly what I need. I know this response was meant for another, but thanks.
Old Jun 10, 2014 | 11:18 AM
W1d0wmak3r's Avatar
W1d0wmak3r
1993_F350: Question
Do you still have the factory 15" x 7.5" wheels?
Old Jun 10, 2014 | 11:23 AM
GoinBoarding
Still need the camber bushings, so you're saving, what $30 to go the block route? I used to bottom out my front end on occasion, but these new springs are progressive rate and have eliminated that issue altogether. Truck just feels more planted without an excessively harsh ride, I'm quite happy I went with CC844 springs. I have Prime, so shipping was free...$67 total for springs.
Old Jun 10, 2014 | 11:40 AM
1993_f350_2013
Yes I have the same wheels as you do. I also have the aluminum ones but I'm gonna do a little bit of work to them....
Old Jun 10, 2014 | 11:42 AM
W1d0wmak3r's Avatar
W1d0wmak3r
$100 for the bushings and springs together isn't bad. I'll probably put new shocks on while I'm at it since I have no clue how old mine are and they look ancient.
Old Jun 10, 2014 | 11:43 AM
1993_f350_2013
What do you mean by bottoming out..? I don't really go off-roading all that much.
Old Jun 10, 2014 | 11:45 AM
W1d0wmak3r's Avatar
W1d0wmak3r
I drove over an hour away to meet a guy and buy a set of wheels this last weekend only for him to stand me up. I'm looking for more 15s, but with proper backspacing to get rid of my rubbing. I'll find some eventually, but for now I'll just not turn all the way.
Old Jun 10, 2014 | 11:46 AM
1993_f350_2013
While your in there you might as well take a big bite and do ball joints, axle u joints, seals, tie rods, rag joints, shocks, brakes, and if your truck don't have them manual locking hubs... That way your all set for a good true alignment.
Old Jun 10, 2014 | 11:49 AM
1993_f350_2013
I'm personally gonna look for a set of 16s because id prefer a 33 10.5 15 tire but they're limited on options so instead I'll go 285/75 16 and I'll have 10 ply so they'll last for ever on a half ton... And be more options!
Old Jun 10, 2014 | 11:51 AM
W1d0wmak3r's Avatar
W1d0wmak3r
I need to do every bit of that except for the HUBs. I have a new set of WARN manual lockers on there now.
Right now I'm replacing the oil pan, gasket, pump, and the motor and transmission mounts.
Old Jun 10, 2014 | 03:48 PM
1993_f350_2013
I think I'm gonna go with the block route. Just cause I know I'll get 2 inches for sure.
