I went to smog my 99 ford f250 super duty yesterday and the check engine light came on and it came up with code p0500- vehicle speed sensor malfunction. I puchased a new sensor from napa (part number vss333) and i was told it could be one of two places- on the tranny or on the rear differential- still cant locate it and no one has been able to tell me a definitive answer. do i even have the right part?
Try it down the page a ways in the 7.3 forum. I don't think there are alot of 7.3 floaters in this forum and might get quicker and better help there.
It should be located on top of the rear differential housing, with a 2 wire plug that goes into it. It has an 8mm bolt that holds the sensor down. just unplug and unbolt and replace
