p0443 code
Old May 23, 2009 | 08:18 AM
doodawg's Avatar
doodawg
p0443 code
i have a 96 f-350 won't start, it turns over pulled a p0443 code
Old May 23, 2009 | 08:28 AM
BlueMule's Avatar
BlueMule
What are you using to get codes? That's a gasser code for the evaporative system.
Old May 23, 2009 | 09:00 AM
plowhand's Avatar
plowhand
Playing in the Dirt
First check all of your under hood fuses, especially #22. If 22 is blown then unplug your fuel heater on the side of your fuel filter housing. Do you have any tach movement while cranking it over? If not replace your CPS.
Old May 23, 2009 | 10:27 AM
doodawg's Avatar
doodawg
i allready replaced the cps all fuses are fine
i had a friend from a local shop pull the code
Old May 23, 2009 | 03:54 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Check your fuel pressure while cranking. Check the Timmerman nut on the IPR for tightness. Check the plug on the IPR. If all of the above are good, get a cap and a plug to fit the high pressure oil supply hoses. Remove the high pressure oil supply hose to one head and cap off the hose and the fitting on the head (if you have a HXP remove it and plug off the locations where it was). Try cranking the truck. If it does not crank, cap off the high pressure oil supply to the other head and reconnect to the first head, try crnking it again. If it cranks on one head, pull the valve cover on the other head, reconnect the high pressure oil supply, pull the #9 MAXI fuse to keep the IDM from firing and crank the engine over while watching the injectors, if you see oil coming from one or more injectors, there's your problem. Oil coming from around the base of the injector means blow o-rings, oil coming from the spill spout means stuck open injector. Let us know what you find.
Old May 24, 2009 | 06:45 AM
doodawg's Avatar
doodawg
that mite be to much for me to do in my apartment driveway
one symtom I was driving home lost alot of power like i had it to the floor just to get home
got home shut it off and restarted ran the same went back a day or so later and it would not start
Gaylin
Feb 8, 2015 03:36 PM
IowanStraight6
34
Nov 2, 2014 01:50 PM
NovaNewfie
1997 - 2003 F150
Mar 9, 2014 10:04 AM
dvlsmstr
1997 - 2003 F150
Feb 2, 2014 06:57 AM
Iceman5192
1997 - 2003 F150
Aug 15, 2013 09:54 PM
