rear diff cover
Old May 23, 2009 | 03:45 AM
ron's power stroke's Avatar
ron's power stroke
clear rear diff cover
check this out
CLEAR GEAR DIFFERENTIAL FITS FORD SUPER DUTY 4WD:eBay Motors (item 120007059781 end time May-25-09 12:18:34 PDT)
Old May 23, 2009 | 03:58 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Wonder how it would look after a few thousand miles ?
Top idea if its stays relatively clear over time.
Old May 23, 2009 | 04:04 AM
ron's power stroke
i was thinking it may turn yellow after its been heated a few times..not sure how i like it so far..its differnt for sure
Old May 23, 2009 | 04:16 AM
Visseroth's Avatar
Visseroth
no kidding, looks like a great idea for sure but how does it hold up, how well does it hold a seal? If it holds up, stays pretty clear and hold a seal then this would be pretty need though I think up here in the north with all the cold temps here and there it would probably become brittle and break.
Old May 23, 2009 | 05:35 AM
ron's power stroke
another good point..its nothing to see 35 to 40 bellow with no wind chill here...
Old May 23, 2009 | 06:23 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
That thing can't be very strong, being clear like that. Not good for offroad. Not for me.
Old May 23, 2009 | 06:26 AM
ron's power stroke
i dont off road my truck..i have a older Ford for that..cheaper to fix and more fun to play..i dont care if i smash that up..BUT NOT MY PSD....but it said just as hard as steel...bullet proof class maybe ??
Old May 23, 2009 | 06:38 AM
miller_feed
I hear your Ron, I don't off road my truck either, but some do. Are you going to be the ginny-pig on this one?
Old May 23, 2009 | 07:24 AM
jdecker88's Avatar
jdecker88
Neat find Ron but I would be worried about it changing colors like you mentioned.
My self I take my truck to the fields but there is no off roading I have ATVs for that.
Old May 23, 2009 | 08:12 AM
megawatt00's Avatar
megawatt00
I'd be a bit worried it says that it is polycarbonate iirc that is plexiglass. If it were Lexan now that would be a different story.
Old May 23, 2009 | 08:28 AM
Ponyboychris's Avatar
Ponyboychris
Now a set of valve covers that where see-thru would be fun. At the very least, when your UVCH came loose, you can see which one is bad without having to pull them.
Old May 23, 2009 | 08:35 AM
Adam0331's Avatar
Adam0331
I think Kris has one of those.
Old May 23, 2009 | 08:59 AM
Izzy351's Avatar
Izzy351
It would be black with sooty-oil in no time, don't ya' think??
I'm about to put my '08 diff cover on. Heading out right now to get lube & longer bolts.
Old May 23, 2009 | 09:02 AM
Ponyboychris
Very true, Coat the insides with Rain-x????
Have fun with the diff cover. I love mine. Be patient with the install so you don't have any leaks.
Old May 23, 2009 | 09:13 AM
Izzy351's Avatar
Izzy351
Rain-X works with water -- not sure how well it would work with oil.
