rear diff cover
Old May 23, 2009 | 12:09 PM
spdmpo's Avatar
spdmpo
I mean no offense to anyone that bought one, but I can't think of a more worthless thing to waste money on. Especially for something that is less strong and more prone to any breakage than the originial thin stamped steel cover.
We all scoff and laugh at those things...
Then again, no one wants everyone's truck to be the same.
Old May 23, 2009 | 01:13 PM
twags6's Avatar
twags6
Originally Posted by megawatt00
I'd be a bit worried it says that it is polycarbonate iirc that is plexiglass. If it were Lexan now that would be a different story.
Polycarbonate is not the same as plexiglass. Lexan is polycarb, acrylic is plexiglass. Polycarb is very flexible in thin sheets and is a component in bullet proof glass. Plexiglass will break just like glass (where the name comes from) if you bend it far enough, not to mention it burns pretty nicely.
Old May 23, 2009 | 01:28 PM
spdmpo's Avatar
spdmpo
I have to admit, it's neat to watch.
YouTube - Clear Gearz
Old May 23, 2009 | 02:29 PM
megawatt00's Avatar
megawatt00
Thanks fopr the refresher Trevor I used to deal with a lot of that when I worked for Titleist. NO so much anymore.
Old May 23, 2009 | 03:13 PM
74baja's Avatar
74baja
That won't rust like my old one. Looks Cool.
Old May 23, 2009 | 06:22 PM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by miller_feed
I hear your Ron, I don't off road my truck either, but some do. Are you going to be the ginny-pig on this one?
no im not getting one..just found it and thought id post it up...149 for a cover is a bit much for me..
i do like the valve cover idea..that was my first thought when i see the diff cover..
if the cover stays black with oil..then i think it would be a sighn to change it out wouldnt it?? good clean oil will settle and slide off of the glass.....durty oil would cling to it..
Old May 23, 2009 | 07:16 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I think you are right with the oil change thing, when it turns black, change the oil. But that would work for the first oil change after installing the clear VC. The only thing that I thinks works being clear, is the degaser bottle on top of the rad. . Wouldn't it be nice to have a clear block and heads? Look, injector #2 is not putting out oil.
Old May 23, 2009 | 09:52 PM
Izzy351's Avatar
Izzy351
Neither will this one. Just got done putting it on (it's the stock 2008 cover):
Old May 24, 2009 | 01:11 AM
Visseroth's Avatar
Visseroth
Oh very nice. I like it. Basically a differential heat sink. Might I ask where you got one so I can get one too
Old May 24, 2009 | 05:31 AM
Kwikkordead's Avatar
Kwikkordead
I found this from one of our forum sponsors, FTE Parts Guy
Th!nkPartsGuy/FTEPartsGuy
Old May 24, 2009 | 08:57 AM
Izzy351's Avatar
Izzy351
I got mine from Ed (FTE/Parts Guy), and went out and bought SS bolts. Or you can get it from Diesel Manor and get it with bolts. Mine was $55 to my door plus bolts/washers (~$20), from Diesel Manor it's $78 plus shipping with non-stainless bolts. Your call.
I used 1 1/2" bolts, and had to double-washer a few of them to keep 'em from bottoming out before they were tight. 1 1/4" would be best, but neither HD or Lowes had them in that size. 1" seemed a bit too short, so I with with the longer ones and added SS flat washers for spacers. Worked well!
Old May 25, 2009 | 03:18 PM
Visseroth's Avatar
Visseroth
I don't see a 7.3 listed there. What cover did you get?
Old May 25, 2009 | 03:21 PM
  #28
ron's power stroke
its for an 08 truck but fits our trucks..
Old May 25, 2009 | 06:12 PM
  #29
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Old May 25, 2009 | 06:14 PM
  #30
ron's power stroke
that looks Kris..how do you like it???
