Fuel pumps
Old May 23, 2009 | 02:04 AM
1950gmcelc's Avatar
1950gmcelc
Fuel pumps
HEY GUYS WHERE DO YOU RECOMMEND GETTING A REASONABLY PRICED ELECTRIC FUEL PUMP KIT FOR MY TRUCK? I HAVE A LEAKING STOCK PUMP AND AM WONDERING IF I SHOULD SWITCH TO ELECTRIC? DO THE THE ELECTRIC PUMPS COMPETLY GET RID OF THE STOCK PUMPS?
Old May 23, 2009 | 02:42 AM
kawa's Avatar
kawa
Altho quite pricey they do indeed get rid of the mechanical pump. You might try: dieselsite.com (I think that is the link, if not someone will correct me)
Rog
Old May 23, 2009 | 03:00 AM
1950gmcelc's Avatar
1950gmcelc
Beans sells a raptor kit which sounds like it is a full kit but i'm not sure. I am thinking about this kit since it is close to the price of a factory pump.
Old May 23, 2009 | 03:17 AM
kawa's Avatar
kawa
The Raptor fuel pump only sells for $100.00? Are you sure about that?
Rog
Old May 23, 2009 | 03:27 AM
1950gmcelc's Avatar
1950gmcelc
Raptor Fuel Pump Only -100 GPH
HIGH END Gearotor Pump Featuring:
- A built in ADJUSTABLE REGULATOR, No Return Line Needed
- 15/16,000 hour Electric Motor
- Flow Rates of 100 GPH & 150 GPH
- VacU Seal Technology (Shaft Seals Under Vacuum Instead Of Pressure for Long Life)
- Wire Screen in Inlet Port for Added Protection
- Complete Installation Kit With: No Drill Mounting Bracket, Wiring Harness, AND
1/2” Big Line Fuel Lines are Standard.
Price: $389.00
Old May 23, 2009 | 03:42 AM
1950gmcelc's Avatar
1950gmcelc
Is it worth the extra money to go to a electric set up?
Old May 23, 2009 | 05:50 AM
Welk49's Avatar
Welk49
I did my own electric fuel system, I like it. If you don't want to have to spend a lot of money I would say either replace your mechanical fuel pump, or do your own electric fuel system. I have less than 500 in my fuel system.
Old May 23, 2009 | 07:45 AM
BlueMule's Avatar
BlueMule
Price: $389.00
That's not for a PSD, it's a lift pump for a Cummins or D-Max and is only good for about 20 psi.
Bean does sell a complete system for an OBS but it's not cheap.
Beans Diesel Performance - 94-97 Power Stroke Complete Single Pump Fuel System
Old May 24, 2009 | 12:16 PM
1950gmcelc's Avatar
1950gmcelc
Hey welk do you have a parts list on your fuel system build?
Old May 24, 2009 | 03:42 PM
Welk49's Avatar
Welk49
yeah I'll get the list and post it for ya.
Old May 24, 2009 | 05:27 PM
Welk49's Avatar
Welk49
ok first pre-filter/water sep. FM100 part # 33640 from the Diesel store
post filter base - 24770
post filter - 33528
got these at Fleet Filter.com
Fuel Pump- 834GSL392 from Full Throttle speed.com
Regulator- Aeromotive 13109 from Summit.
The Regulator has 6AN threads.
I used a 6AN to a 3/8 barb for the return to the tank
And used 6AN to 4JIC fittings for the heads and re-used the existing stock hoses from the heads.
For the Supply I used 3/8 push lock fittings and hoses from filter and pump set-up.
Used a Air Hose 3 way I got @ Lowes. 3/8 into the 3-way and have (2) 1/4 hoses that run and attach the metal lines that are already going to the back of the heads.
Electrical I used wire I had laying around to wire it up but did get a fuel pump relay from Summit. If you search other threads you'll find the wiring diagram for it. Some have also used a relay and fuse out of a junk yard truck to make the wiring have a more factory look.
Some people have also used braided AN hose and fittings to do there fuel systems, but you'll spend more money on that. It might look a little better, but I wasn't after looks I was after function. I am very happy with the electric set-up.
Old May 26, 2009 | 12:56 AM
1950gmcelc's Avatar
1950gmcelc
Do you have any pics of the install?
NBC-Steve
15
Feb 16, 2014 10:51 AM
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
drewdole
58
Feb 19, 2010 03:14 PM
drewdole
Jan 18, 2010 09:45 AM
classyfish
May 18, 2002 12:45 PM
