Intake Manifold bolt torque
Old May 22, 2009 | 04:04 PM
Help I M Stuck's Avatar
Help I M Stuck
anyone know the torque and sequence for the intake manifold bolts? I was told 120 inlbs...just double checking..
Thanks!
Old May 22, 2009 | 05:39 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Haynes says 96 in-lbs
According to the Haynes manual, the sequence is to start on the drivers side at the rearmost outside bolt, then come to the front most inside bolt, then to the rearmost inside bolt, then zigzag your way back to the front. Tighten this side to spec before doing the other side. After following the same sequence for the other side, check the side that you did first once more for the proper torque..
Old May 22, 2009 | 05:54 PM
freeride808's Avatar
freeride808
specs
It is 8 Ft Lbs. They say to double check but i would triple check
Old May 22, 2009 | 06:22 PM
69cj's Avatar
69cj
8 ft. lbs. = 96" lbs.
Old May 22, 2009 | 07:47 PM
Help I M Stuck
ok, i'm not a dummy when it comes to doing the work..just when it comes to using a torque wrench. I guess i should have said..what to i set the torque wrench on so when i check them and the wrench clicks/snaps..i know i'm done and move to the next one.
Old May 22, 2009 | 09:30 PM
SteveBricks
FTE Emeritus
The bolts torque to 96 inch lbs - that's what you set the wrench to.
Old May 22, 2009 | 11:02 PM
bismic's Avatar
bismic
You could also set it to 10.84656 Newton-meters
tomkin
6.7L Power Stroke Diesel
Nov 6, 2016 11:56 AM
Hopsing69
Jul 9, 2013 04:32 PM
superduty1967
Oct 18, 2012 09:17 PM
Payner44
Nov 11, 2008 09:19 PM
6t56
401, 477, & 534 SD Engines
Oct 26, 2007 07:39 PM
