Turbo timer???????
Old May 20, 2009 | 10:16 PM
warpedsportz23's Avatar
warpedsportz23
Turbo timer???????
Hey guys whats going on. I was looking into getting a turbo timer for my 2006 f250 and I was wondering if there was any one brand that was better than the others. I'm also wondering what you guys use. I'm just looking for a system thats reliable and I won't have any trouble. I'm new to diesel's so any help would be greatly appreciated.
Thanks in advance
Old May 20, 2009 | 10:19 PM
riggz's Avatar
riggz
You can get an alarm with a turbo timer built in. It's not automatic but it can be activated with the push of a button. Also if you have an EGT gauge you can see when the temp gets below 400* and shut it down then. Also if you run synthetic oil you don't have to worry about it at all.
Old May 20, 2009 | 10:23 PM
adambomb's Avatar
adambomb
i use a Viper 791 that works really well for my truck. i don't know if you like/need these features but it also is an alarm and has a pager that tells you if someone is breaking into your truck and ID if its the hood or the door in a little black and white diagram thingy on the remote.
Old May 20, 2009 | 10:34 PM
warpedsportz23
Thanks for your input riggz and adambomb. I would love to replace the factory alarm system and purchase a viper system. Unfortunately I can not, due to my in-sufficient funds, if you know what I mean. So as of now I'm just looking to get a turbo timer that way I do not have to sit in my truck and wait for the turbo to spool down. However, I do also like your idea of the gauge riggz. What does all of that entail and how much would that set me back?
thanks guys.
also, Would either a timer or a gauge void my warranty.
*edit* I'm looking for something like this
http://store.summitracing.com/partde...5&autoview=sku
Old May 20, 2009 | 10:40 PM
riggz's Avatar
riggz
From what I've seen the cost of a turbo timer is the same or just a bit less than an alarm w/ turbo timer & remote start. I got my Viper 5900SST for around $225 and installed it myself. A single EGT gauge will run about $130-175 depending upon the brand.
Old May 21, 2009 | 08:27 AM
joe blow's Avatar
joe blow
Turbo Savers - http://www.usdieselparts.com
This is what I use, didn't buy it from here. It has lasted for 5 years now...
Old May 21, 2009 | 08:43 AM
ingman's Avatar
ingman
I just let it cool, then get out and leave. I also don't drive it really hard just before I shut it down. To me just seams like something else to spend money on. Just my two cents.
Old May 21, 2009 | 12:09 PM
joe blow's Avatar
joe blow
ingman,
You are absoulutely correct. If I knew what I know now...I would not have purchased a turbo timer.....just a gauge is sufficient.
I can pull a long heavy grade with my 5th wheel, exit the freeway and by the time I get to the place I am stopping at it takes about a minute to cool down to 350*....I am straight piped though....
Old May 21, 2009 | 10:46 PM
warpedsportz23
i thought i was set on finding a turbo timer... but you guys are getting me thinking. What does installing a gauge entail? Can I just plug it into the factory harness or do I have to run my own wires to the engine? I now I can install which ever I just don't know if I have the time( yeah I'm that busy). joe blow: One question if you had to guess, if it takes your staight piped 6.0 a minute to cool down, what would I be expecting from a 6.0 with the stock exhaust
also If I decide to get the gauge what other gauges should I look into? because I most likely will get the A pillar gauge mount.
thanks
Old May 22, 2009 | 12:44 AM
joe blow's Avatar
joe blow
A pyrometer gauge involves drilling the bottom of the exhaust manifold for a temp probe and simple wiring for the gauge. Not very difficult, if you have some mechanical know how and a decent set of tools.
In regards to the cool down with a stock exhaust...not too sure, since you have a CAT which retains heat and the muffler which kinda restricts some exhaust flow and retains some heat as well. A gauge will be very helpful.
Gauges I monitor..EGT, trans, coolant and boost.
I have a Quadzilla commander gauge (stand alone digital) that monitors all four on one screen.
Old May 22, 2009 | 10:59 AM
yankee88's Avatar
yankee88
I am going to have a pyro installed I want it after turbo I think it would be the most accurate turbo temp.Installer think pre-turbo.Need input.
Old May 22, 2009 | 10:33 PM
warpedsportz23
yankee88 i'd appreciate it if you did not post your questions in my thread. thanks.
joe blow: I am going to look into the commander gauge. Is that thequadzilla the only one that makes a commander gauge? I suppose this would be the same install procedures correct? also, will instalation of a gauge void my warranty?
Thanks guys ya'll are helping me out a bunch.
Old May 22, 2009 | 11:05 PM
joe blow's Avatar
joe blow
WELL.....No it will not void your warranty, BUT if your dealer is anything like my ford dealer was.....These POS idiots hassled me everytime I brought my truck in because of those particular gauges.
