fuel line help
Old May 22, 2009 | 03:55 PM
crzycrazycarl's Avatar
crzycrazycarl
fuel line help
I got my pieces of fuel line today for on the lift pump. i have all three lines off. can the low one be put on without removing the fuel filter housing? if not any tips on pulling it out. thanks allot
Old May 22, 2009 | 04:42 PM
BlueMule's Avatar
BlueMule
well..........maybe you could get the bottom hose on but I don't see how you'd be able to get the clamp tight. There's only two bolts that hold the canister in place. On the right side of the bowl there's a connector for the wiring harness that goes to the heater, filter light and water light and on the other side you need to unplug the IPR. Once those two are unplugged the sensors and harness will come out with the bowl.
Old May 22, 2009 | 07:58 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You also have to remove the two fuel lines coming from the heads (front of the FPR, high pressure lines), the fuel return line to the tanks (rear of FPR) and the hose for the fuel filter housing drain (bottom of the drain valve).
Old May 22, 2009 | 08:08 PM
crzycrazycarl
yea, i ended up taking the two bolts out and pushing the housing towards the front of the truck enough to get the line in, worked pretty good.
alchemist1
Sep 28, 2012 06:48 AM
Suomi Powerstroke
Nov 16, 2009 10:10 AM
AndysFords
Aug 3, 2009 09:59 PM
joe f350
46
Apr 20, 2009 11:46 AM
pancake
Garage & Workshop
16
Oct 5, 2003 04:59 PM
