so long as its not touching anything it should be just fine, however on a more personal note (if thats what you want to call it) a rubber fuel line just plain looks sloppy. some steel line and a 10 doller tubing bender, or and old pulley, would look alot better, and would last longer too.
OK, so you want to put a slip on hose fitting at the filter head and then just clamp the hose on to what is left of the hard line at the injector pump,
correct?
That should work fine even if it won't look as nice. If nothing else its a decent repair until you can locate another line with fittings at a wrecker or something.
I always go to a parts house and buy Trannsmission cooler line, it is rated for around 200 psi, it looks the same as rubber fuel line but it is a lot tougher.
joe, i have a rubber fuel line for the first 6 inches of return out of the ip. it does not look professional, but it works great, and no the heat does not bother it
