Antifreeze leak
Old May 30, 2009 | 09:07 AM
  #31
74baja's Avatar
74baja
Hey,
I am putting the new pump together. What should I torque the intake and output fittings fasteners to?
Old May 30, 2009 | 09:10 AM
  #32
74baja's Avatar
74baja
And should I use threadlocker?
Old May 30, 2009 | 09:12 AM
  #33
mueckster's Avatar
mueckster
All bolts should torque about the same 18 ft-lbs, according to my manual.
Old May 30, 2009 | 09:15 AM
  #34
mueckster's Avatar
mueckster
I use anti-sieze or pipe dope on the threads. There can be a "next time".
Old May 30, 2009 | 01:38 PM
  #35
60RatRod's Avatar
60RatRod
No, just use a good anti sieze or Pipe Thread sealant.
Old May 30, 2009 | 03:28 PM
  #36
74baja's Avatar
74baja
How do I add antifreeze and water to replace what I took out? I have 2 gallons of antifreeze and 2 gallons of distilled water.
Old May 30, 2009 | 03:48 PM
  #37
60RatRod's Avatar
60RatRod
50/50 mix, just add to where the radiator cap goes on. run motor after filling and wait for thermostat to open and add the rest.
Old May 30, 2009 | 03:52 PM
  #38
74baja's Avatar
74baja
I've got to be honest, I can't find the radiator cap.
Old May 30, 2009 | 03:55 PM
  #39
60RatRod's Avatar
60RatRod
Its on the plastic overflow reservoir, not on the radiator.
Old May 30, 2009 | 05:30 PM
  #40
74baja's Avatar
74baja
All done. NO LEAKS! Thanks for the help folks!
Old May 30, 2009 | 05:59 PM
  #41
PaysonPSD's Avatar
PaysonPSD
Good Work Jack. No more spotting.
Old May 30, 2009 | 06:15 PM
  #42
60RatRod's Avatar
60RatRod
Rock on brother, we knew you could do it!
rjwood5
Mar 17, 2013 05:24 PM
gbrewer
Dec 27, 2010 11:22 PM
knecoli22
Sep 14, 2010 09:37 PM
ponyboy123
Apr 26, 2010 10:00 PM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
