New Dash?
Old May 22, 2009 | 03:54 AM
redbug's Avatar
redbug
New Dash?
Hello,
I have an 85 F250 Diesel. Is it possible to get a new dashboard, or just a skin to go over it? Mine has a crack right down the middle.
Thanks,
redbug
F250, C6,6.9, Cruise, Air, Tilt Wheel.
Old May 22, 2009 | 06:02 AM
Built_Ford_Tough_757's Avatar
You can go to a junk yard and get the entire dash, or LMC Truck (lmctruck.com) and get a skin. Just check out there online catalog.
Old May 22, 2009 | 02:52 PM
Eddiec1564's Avatar
Eddiec1564
I use a dash cover on mine, thats after getting another dash pad from the JY and a month later that cracked!
Old May 22, 2009 | 02:55 PM
nflfreak43's Avatar
nflfreak43
its easier to get a cover. the dash pads that are used if not already cracked are typically getting ready to crack due to the heat and cold and age.
Old May 22, 2009 | 04:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
If the JY dash isn't cracked yet, you can try using vaseline on it. It will help soften up the vinyl again, so it's not brittle, (if not too far gone). Puts back in the petrolium oils that have leached out etc.
These pads are still avaliable new at Ford as well.
But they are charcoal gray only, and are $$$ pricey.
Old May 22, 2009 | 11:23 PM
If you do go with a ford pad, specify for a large box style truck... say like a '95ish year. Someone know what year and model? I'm just approximately guessing..
Old May 23, 2009 | 10:21 AM
nflfreak43's Avatar
nflfreak43
i believe its like F550 and 650's if not mistaken
Old May 23, 2009 | 01:28 PM
81-F-150-Explorer
1980-1983 - F-100
1980-1986 - F-150 through F-350
1980-1999 - F-600 through F-900
