Engine miss
Old May 22, 2009 | 12:52 AM
bustech81's Avatar
bustech81
Engine miss
Hi all. 01' super duty f250 4wd,250k miles. Idle's very rough and does not get any better with temp. No logged faults however a #7 cylinder contribution failure popped up with the test. No smoke from the exhuast. All injectors sound fine on the buzz test. Pulled the pcm relay and cranked the engine and it cranked fairly smooth. Thinking possibly a failed injector. If it cam unplugged it shoudn't buzz yeah? Any idea's would be great thanks.
Old May 22, 2009 | 06:16 AM
Visseroth's Avatar
Visseroth
Time to take it to someone with the right equipment and have an injector test run. They can run a click like test and determine if you have a failed injector.
My thought anyhow
Old May 22, 2009 | 07:01 AM
Kwikkordead's Avatar
Kwikkordead
You either have a failed injector or the wiring harness is coming unplugged inside the valve cover.
I'll be watching this thread.
kurboman
Oct 26, 2014 08:33 PM
wackercattle
Aug 25, 2013 10:06 PM
carltonwebb
Jan 14, 2012 11:15 PM
Aki_A
Mar 22, 2011 05:33 AM
Yougotthehit
Oct 8, 2009 07:36 PM
