C6 shift kit install
Old Jun 25, 2002 | 11:42 AM
loudfords's Avatar
loudfords
I will be putting a Transgo kit in my C6 soon. Does anyone have any installation tips? Can I install it ok with the tranny out of the truck? Like I mean tranny tipped on it's side on the ground?
Old Jun 26, 2002 | 06:05 AM
DeenHylton's Avatar
DeenHylton
It would be easier to keep the little steel ***** in place if you turned it upside down (pan facing up). Also make sure you buy or at least rent/borrow an inch-pound (NOT foot-pound) torque wrench to re-torque the valve-body. I've seen the trannys fail to shift either right away or even after several thousand miles because the valve body was not torqued correctly during assembly. Good luck, Deen
Old Jun 26, 2002 | 11:15 PM
ford_nut's Avatar
ford_nut
hey deen
i am curious--why does it matter if you use a inch lbs wrench to torque the valve body? my C6 was working fine until i installed the B&M shift improver kit---i didnt use an inch lbs wrench--just the snug it up--and feel method. Now the thing is acting real crazy...it has morning sickness symptoms and when it does warm up, the shifts are sometimes hard n snappy or erratic--what gives??
regards
ben
Old Jun 27, 2002 | 06:59 AM
DeenHylton's Avatar
DeenHylton
Ben, I'm not familiar with that particular shift kit but you can call B&M for technical assistance.
As far as retorquing the valve body correctly...The valve body has to maintanin a certain amount of hydraulic pressure to control the shifts in the tranny. If you have a leak ANYWHERE in the valve body it will not function as designed. Not enough torques and you'll leak around the gasket surfaces...too much torque and you'll warp the valve body so it again will leak.
Old Jun 27, 2002 | 08:49 AM
BroncoScott's Avatar
BroncoScott
mustangmatt
Oct 16, 2018 03:49 PM
Justin73supercamper
Aug 31, 2016 07:55 AM
Scolesy8
Feb 2, 2009 09:48 PM
hdman6
Aug 2, 2008 04:19 PM
WillFordTruck
Aug 14, 2007 07:13 PM
