5 to 8 lug conversion
Old Jun 20, 2002 | 12:55 PM
brokebronco's Avatar
brokebronco
BROKEBRONCO
Old Jun 20, 2002 | 07:15 PM
brokebronco
sorry got sidetracked.
i am interested in converting the ttb 44 from 5 to 8 lugs.
ideally i would install a d60 but timing and fundage are not there.
sabreforce.com had a kit listed but went out of business before i could get a reply or a price. any help would be great.
BROKEBRONCO
Old Jun 24, 2002 | 07:02 AM
DoubleA's Avatar
DoubleA
I did this on my truck. It is pretty easy.
You'll need everything from the balljoints out from a chevy light duty 3/4 ton. they use a dana 44 too.
the spindles are the same bolt pattern so just pull off your spindles back to the knuckle, knock out the spindle studs, (the Chevy stuff needs longer studs because there is a plate that holds on the caliper inbetween the spindle and knuckle) and replace with the Chevy spindle studs, caliper holder, axle end, and spindle (you'll have to cut off the ttb caliper slides and grind a little to give room for the Chevy calipers).
I've had mine on for about 20K miles, stops alot better.
Good luck, let me know if you have any questions.
Aaron
Old Jun 26, 2002 | 04:15 PM
brokebronco
doubleA
thanks for the info, i am going to try to find the needed parts to do the job. unfortunatly i just got orders to germany and i won't be able to do the conversion untill next year.
BROKEBRONCO
Old Jun 27, 2002 | 12:54 PM
brokebronco
>doubleA
>year.
>BROKEBRONCO
Did I say Germany? oops, I meant Korea.
BROKEBRONCO:-staun
Old Jun 27, 2002 | 01:29 PM
DIFFMASTER's Avatar
DIFFMASTER
brokebronco
Texas Chapter
Aug 11, 2002 12:11 PM
brokebronco
Aug 8, 2002 06:45 PM
brokebronco
Aug 8, 2002 08:18 AM
brokebronco
1978 - 1996 Big Bronco
Jul 17, 2002 02:40 PM
brokebronco
Jun 15, 2002 11:26 AM
