vibration in rear
Old Jun 27, 2002 | 03:51 PM
beartracks's Avatar
beartracks
vibration in rear
I've tried to solve this problem off an on for a long time. I have an oscillating vibration that occurs between 55 and 75 MPH. It seems to come from the rear end. The frequency is about 3 seconds. Sort of a shudder every 3 seconds. It's not real pronouced and seems to vary in intensity with road condition.
I've balanced and checked tires and rims for round. Balanced drive shaft. The differential is a traction lock with 25,000 miles on it. Axles and bearings recently replaced. springs and shocks look good.
Anyone else have this problem? Could it be related to the traction lock or it's adjustment? It doesn't seem like a tire problem as it oscillates.
Bear Tracks
Old Jun 27, 2002 | 06:10 PM
DIFFMASTER's Avatar
DIFFMASTER
vibration in rear
It has been my experience that usually points to a driveshaft out of balance. Did the driveshaft shop you took it to balance it, or just spin it in their lathe? Most driveshaft shops think that if the tube is straight, it's balanced, not true. They need to be balanced. I have seen torque converters, flexplates and engine accessories have harmonic vibrations as well.
Old Jun 28, 2002 | 11:17 AM
beartracks's Avatar
beartracks
vibration in rear
[updated:LAST EDITED ON 28-Jun-02 AT 12:19 PM (EST)] Drive shaft had weight added to it. Problem doen't change when I change gear or throw it in nuetral. "U" joints were replaced with the balance job. Very perplexing.
I think I'll turn it 180 degrees in the pinon joke and try that.
Bear Tracks
Old Jun 28, 2002 | 12:28 PM
rabidranger's Avatar
rabidranger
vibration in rear
wildstang
Jul 27, 2017 08:57 AM
1911fan
6.7L Power Stroke Diesel
May 11, 2017 02:53 PM
MarkF
Nov 21, 2016 07:41 AM
Superduty.pride
1978 - 1996 Big Bronco
Mar 2, 2016 03:16 PM
cadunkle
17
Jan 23, 2009 03:58 PM
