Its not death wobble. I have an oscillation in the steering wheel at speed in a turn. Feels like the pump is trying to straighten the wheel then gives up then trys again then gives up etc etc..... The oscillation is slow so its not like the wheel is shaking or about to fall off. The faster you go the more pronounced it is the tighter the turn the more pronounced it is. Doesnt matter left or right. Seems like its there at any speed but just gets worse the faster you go.
Hubs are in auto. The 4wd works but i havnt jacked the truck up to see if they are stuck. I believe if you loose the vacuum booster it just becomes more difficult to steer and mine steers easy like the old gm cars from the 60s.
With transfer case unlocked you should be able to manually turn the fron drive shaft, no need to jack up. Should be able to see both u joints spin at the knuckles
My guess would be the steering box and/or linkage. The resistance you get when you turn indicates loose mounting bolts or worn linkage ball connections. If your tires don't bounce when you are driving straight, it isn't a balance problem.
