Turbo Pedestal help needed!
Old May 21, 2009 | 03:31 PM
jasvid's Avatar
jasvid
Hi Guys,
Great site! I have learned a lot here - mostly searching and lurking.
I have a 97' F-350 and I have a solid oil leak at the pedestal. There is no oil leaking at the front of the valley and the pedestal is covered in oil. I went through about 5 quarts in 600 miles and occasionally had blue-white smoke come out the exhaust in spurts - probably happened about 50 times in those 600 miles. Does this
I just brought the truck to the mechanics - he confirmed that the leak is at the pedestal. The rub - he said we are looking at $600 for a rebuilt pedestal and $400 for labor.
What are my options? I live in Wisconsin - can I go with the removed ebpv pedestal mount? This truck is a work truck and is generally used for longer trips pulling a trailer - not a whole lot of short hops. If this is feasable, where can I find a pre-fabbed version - I looked at dieselsite with no luck.
If I can't go with the ebpv delete, what do you guys think of the rebuild kit? My mechanic hasn't even heard of this option, although he has owned 3 7.3 trucks of this generation....
Should I just go new?
Any and all input is welcome! Thanks, Jason
Old May 21, 2009 | 04:11 PM
WALJON's Avatar
WALJON
Wow that's pretty pricey! Do a search on EBay you will find that you can pick a ped up for a couple hundred bucks with or without the EBPV actuator. maybe try to change it out yourself or find someone else to change it for you other than this person.
Old May 21, 2009 | 04:35 PM
superduty4x4's Avatar
superduty4x4
If you go scrounging on Ebay or the junkyards, you need to make sure you don't end up with a late 99-03 pedistal- they are different (taller). Another OBS truck or an early 99 pedistal will work fine.
I would suggest doing the work yourself, from what I read the job isn't all that bad. You'll need new O-rings for the pedistal, check out guzzle's site for the O-rings, and he may even have the pedistal rebuild kits by now.
Old May 21, 2009 | 06:53 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Do a search on ebay for johnsmith04shop (seller name) or go to his web site: Rebuilt Turbochargers| Turbocharger Kits| Turbochargers| Salt Lake City, Utah ( Ron's Turbo Service) Alot of people on here have used him, I have and he does great work, is easy to deal with and will answer any question you have, also fast shipping. I think that a stock replacement turbo is around $550. Don't buy a new one get a rebuilt one, he rebuilds them better than new and they cost less.
If you can turn a wrench you can change out the turbo, a couple of bolts are a little bit of a pain to get to but with the right tools it's not to bad of a job and will save you about $400. There are a bunch of write ups on here about turbo replacements.
Old May 21, 2009 | 07:45 PM
FARM69's Avatar
FARM69
I couldn't agree more with plow. Changing out the charger is not too difficult, but it will take some time to get through it.
Where are you located? Put up your location in your profile and you might have someone close to you that can give you a helping hand.
Old May 21, 2009 | 08:12 PM
jasvid's Avatar
jasvid
Thanks for all the replies - I appreciate it all.
Does anyone have any input on whether I should eliminate the EBPV if I live in Wisconsin?
Farm and Plow - Are you suggesting that I should just replace my entire turbo (does that come with the pedestal attached?) rather than trying to deal with the pedestal?
Old May 21, 2009 | 08:29 PM
FARM69's Avatar
FARM69
No, but I'd definitely go through your charger and make sure everything is up to par since you will have the unit off.
There are many people on here that live up north and do not run the EBPV. It gets pretty cold in Iowa and I've never had a problem.
I remember seeing pedestals for $300? Maybe cheaper? I've been off the net for awhile as I'm finishing planting. I actually have the one off of my truck. PM me if your interested.
Old May 21, 2009 | 11:09 PM
BlueMule's Avatar
BlueMule
Non EBV Turbo Pedestal 94-97 7.3L Ford Powerstroke Diesel
Old May 22, 2009 | 11:24 AM
rideracelivemx7's Avatar
rideracelivemx7
hey man, i just replaced my turbo in whole and i have that still kicking around, the tubo is bad, needed a rebuilold pretty bad so i didnt bother, needed bearings, shaft and wheels( i effed up the wheels apon tinkering!) but ill send it to you in whole pretty cheap, no leaks or anything, just switch over your turbo and possibly new orings, i reused the base ones on my block and there still good so i dont know, pm me if you want it, i just want it out of my garage. ebpv is still on it! and functional.
Old May 22, 2009 | 12:37 PM
Neal 97 250's Avatar
Neal 97 250
jasvid,
I would only replace the pedestal if you want to go without the EBPV. Do not replace the turbo if there is nothing wrong with it.
If you want the EBPV still on the truck I would just remove it and replace the o-rings. Are you sure the EBPV is the part of the pedestal that is leaking? Most of the time it is the o-rings under the turbo or the ones under the pedestal.
Old May 25, 2009 | 09:40 PM
RubberDuck's Avatar
RubberDuck
One thing to think about. It may NOT be the pedistal leaking. If you do the job yourself, take the turbo and pedistal to the work bench. Apply air to the pedistal and plug the other hole with your thumb. Carefully inspect the center section of the turbo. We had one that had a hair line crack and would dump crazy amounts of oil. I would have never found it had it not been for someone telling me about that. Just something to concider. I thought it was farm that told me, but I can't remember at this moment.
Old May 26, 2009 | 01:45 PM
matt71's Avatar
matt71
Here is a pedastal with the EBPV deleted for $95.00 from Ron's Turbo store on Ebay
94 97 POWERSTROKE TURBOCHARGER PEDESTAL TURBO FLANGE:eBay Motors (item 110393278820 end time May-28-09 14:24:49 PDT)
Old May 26, 2009 | 01:46 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by Neal 97 250
jasvid,
I agree. I was thinking why to change the pedestal, maybe only are bad o-rings, but you should be sure that the EBPV part is not leaking.
Yea, I remember that, so also you should to check if it isnt cracked. And RD, IIRC was Cuda Jim
20powerstroke02
55
Oct 31, 2016 06:38 AM
fleonardis
Mar 16, 2013 07:16 PM
Franko72
23
Nov 22, 2012 01:17 PM
derek0525
Nov 23, 2010 10:22 AM
enduringexplorer
16
Apr 29, 2005 07:44 AM
