How to tell if you have a Non-roller or roller block
I've asked several mechanics, they say the only way is to look at the lifters.
Is there another way, I have a 351w MFI ( Manifold Fuel Injection)
1996 Ford F-150.... How do I tell if it's a Roller or Non-roller. Or some way I can find out?
Roller cams use a lifter with a small, very hard wheel on roller bearings that follows the shape of the lobe. Roller cams are more expensive than flat-tappet cams but offer more lift for the same number of degrees of duration.
This also reduces friction between the lifter and camshaft, so the parts don't wear out.
Happened to be snooping around this morning trying to figure out when 351's (5.8L's)went to roller blocks. Near as I can tell, '94-up were roller capable blocks (not necessarily equipped with a roller cam from the factory though..aka Lightning). Block ID # of F4TE-AA. While not the point of my search, I do believe that the 5.8's had roller cams installed after about 95 or 96.
I think this info is correct, but can someone verify this for me (as well as the OP).
Thanks, Mike
Thanks, Mike
I know that 302's were roller equipped in Mustangs like my '87 GT (think '85 or '86 were the first.) I don't believe truck 5.0's were roller cam equipped until at least '92 and more likely the '94 model year when they got a higher performance cam and definitely (at least for the 5.0) changed to roller.
BigBlocker0248
27
07-01-2016 03:25 PM
handyman43358
12-06-2009 09:04 PM
sparky
05-21-2009 08:33 PM
