Torque specs?
Old May 20, 2009 | 09:25 PM
Ryan50hrl's Avatar
Ryan50hrl
Torque specs?
Anyone know the torque specs for the lower coilover bolt on our trucks???
Old May 20, 2009 | 10:46 PM
Ford Fx4's Avatar
Ford Fx4
Here is what I found.
Not sure if what your looking foe is in there....
Torque Specifications Description Nm lb-ft
Wheel nuts 204 150
Front Suspension
Wheel hub-to-wheel knuckle bolts 200 148
Tie-rod end nut 150 111
Front axle-to-wheel hub nut (4x4) 27 20
Upper ball joint nut 115 85
Upper arm-to-frame nuts 150 111
Lower ball joint nut 150 111
Lower arm-to-frame bolt and nut 300 222
Shock absorber upper mounting
plate-to-frame nuts (M10) 48 35
Shock absorber-to-lower arm
bolt and nut (M20) 475 351
Stabilizer bar bracket-to-frame bolts 48 35
Stabilizer bar-to-link nut 133 98
Stabilizer bar-to-link to
lower control arm nut 90 66
Anti-lock brake sensor bolt 18 13
Caliper anchor plate-to-wheel
Caliper-to-anchor plate bolts 32 24
Old May 21, 2009 | 03:32 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
can't remember if you are 4x4 or 4x2...so I'll post both
in either case, it is 351 ft-lbs...I only had a 0-250, so I maxed my Torque wrench...then I used the old "Gudentiite method"
4x4
4x2
Old May 21, 2009 | 07:55 AM
Ryan50hrl's Avatar
Ryan50hrl
damn....i guess i need a bigger torque wrench....LOL....
starmilt
Apr 14, 2023 01:53 PM
green_95
Jun 17, 2016 12:37 PM
flamesoldier
May 21, 2013 09:59 AM
fordpride
Jan 10, 2010 06:38 PM
64F-100
Apr 16, 2009 06:20 AM
