oil pressure
Old May 20, 2009 | 08:27 PM
RyAnIs1's Avatar
RyAnIs1
oil pressure
my 1977 f-150 351m, when you first crank it, the oil pressure runs at 55psi, after it warms up it drops to 13psi. is that to low? is so what is a normal oil pressure when wamed up?
Old May 20, 2009 | 09:09 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
13 psi at idle? That's fine.
13 psi going down the road? That's bad.
Josh
Old May 21, 2009 | 04:02 PM
RyAnIs1's Avatar
RyAnIs1
What is normal?
Old May 21, 2009 | 04:31 PM
Bullitt390's Avatar
Bullitt390
Answer my question first...
Old May 21, 2009 | 04:35 PM
Old Brown Truck's Avatar
Old Brown Truck
The 351M/400 motors are kinda famous for having very low oil pressure at idle. I've heard of cases of 5psi or less. We are talking idle right? Are you hearing ticky lifters?
Old May 21, 2009 | 08:34 PM
RyAnIs1's Avatar
RyAnIs1
it runs at 13psi at an idle, abouts 18-20psi driving
Old May 21, 2009 | 08:54 PM
Bullitt390's Avatar
Bullitt390
That's not good. I would hope for at least 40 psi at 2000 RPM, but the rule of thumb is 10 psi per 1000 RPM. So 20 PSI at 2000 wouls suffice.
I have heard of the 351M and 400 barely getting much more than 0 at idle.
How many miles on the engine? Have you recently changed the oil filter?
Josh
Old May 21, 2009 | 09:01 PM
shadowviper12345's Avatar
shadowviper12345
i have an oil pressure problem with my 302 but the rear main is leaking so i think thats probly the problem. im going to replace the rear main this weekend so that will hopefully solve the problem.
Old May 21, 2009 | 09:51 PM
79_408_Clevor's Avatar
79_408_Clevor
my 302 runs sometimes close to 60 psi, but thats with ftf (foot to floor), usually runs bout 20-45 cruisin, depending on temp and rpm's.............. 18-20 is low, but its somethin.... I'd get the oil restricter kit, then an oil pump
Old May 22, 2009 | 12:26 PM
shadowviper12345
when i replace the rear main im going to put in a high flow oil pump
Old May 22, 2009 | 02:46 PM
79_408_Clevor
would you mean high PRESSURE or high VOLUME???? there is a difference and yes they do sell both, 351M/400's need higher pressure, just in case you didnt know
Old May 22, 2009 | 03:45 PM
fmc400's Avatar
fmc400
MSEE
Bandaid fixes like this are a good way to shear a distributor roll pin.
Old May 22, 2009 | 07:27 PM
shadowviper12345
what is the difference?
Old May 23, 2009 | 07:13 AM
duste's Avatar
duste
The 351M's were famous for loosing oil pressure, I have one noe that does exaclty what yours does. Good pressure cold then it drops right off when hot. If the rest of the engine is good , doesn't knock or smoke. I would replace the mains and rod bearings. If they are the stock ones in the engine now, you can order 2 thou oversize to cover crankshaft wear and a few hours later you should have good pressure again.I did this to 2 of mine years ago and they ran for years afterwords and I have a 4X4 now that I'm fixing that will get the same treatment. If the engine is shot , swap in a 460,easy to swap in, same gas milage , more power and they are bullet proof.
anthonym92
Apr 4, 2015 02:25 PM
insane96
Feb 17, 2013 08:49 PM
Piolet
May 21, 2012 09:58 PM
51ford fan
Flathead V8 & Flathead 6
Jan 25, 2005 08:27 PM
stepside64
Jul 5, 2004 06:34 PM
