Two-Piece Drive Shaft question
Old May 20, 2009 | 05:52 PM
Built_Ford_Tough_757's Avatar
My truck has a two section drive shaft because of how long it is. So in the middle there is a support to hang it up from the ground. Inside, there is a rubber piece that goes in-between the frame strap and the bearing. It got messed up and got crewed up. Anyone know where I can get a new rubber piece before my pemporary shaft does the same thing? ( It may last only a few weeks.) If you need a picture, let me know.
Old May 20, 2009 | 06:16 PM
Diesel_Brad's Avatar
Diesel_Brad
The piece you are refering to is called a carrier bearing. Most auto parts stores will carry it. It is a complete assembly rubber and bearing as one
Old May 20, 2009 | 09:30 PM
Okay, Thanks
Old May 21, 2009 | 02:31 AM
Sycostang67's Avatar
Sycostang67
They usually run about $20 and aren't too difficult to install.
Old May 21, 2009 | 05:50 AM
Big Ben's Avatar
Big Ben
They also list them as center support bearings. I remember trying to look these up in the computer when I was in parts and it was always listed under that.
Custom Junk
Sep 16, 2012 04:13 AM
Witty73
Oct 6, 2010 09:28 AM
harold31816
2004 - 2008 F150
17
May 25, 2004 01:20 PM
KJKozak2
Apr 18, 2002 12:13 AM
