PCM number?
Old May 20, 2009 | 04:38 PM
gasgrunt88's Avatar
gasgrunt88
PCM number?
Where do I find the PCM and number required to order my DP Tuner?
Old May 20, 2009 | 04:49 PM
Trouble1263's Avatar
Trouble1263
You have to remove the PCM from the firewall to get this number..Consider it a test run for when you install the DP..Make SURE the keys are NOT in the ignition when doing this!
Old May 20, 2009 | 05:03 PM
big poppa's Avatar
big poppa
You also can use your vin no#, I gave that to Jody when I ordered mine but call Clay and see if that will work with him..
Old May 20, 2009 | 05:31 PM
megawatt00's Avatar
megawatt00
The PCM is located on the drivers side of the truck under the fuse panel in the cab. You have to remove the pcm to see the code. There is also another mwthod that I ended up using. The connector that goes through the firewall to the pcm has the code on it. Take a flash light and an inspection mirror and you can read the code off the side of the connector. It is facing the drivers side fender
Old May 20, 2009 | 05:53 PM
superduty4x4's Avatar
superduty4x4
I found it easier to spend 10 minutes pulling the PCM to see the code, but that's me.
Old May 20, 2009 | 06:08 PM
megawatt00's Avatar
megawatt00
I know but sometimes I do things just to see if they can be done.
Kinda like some of the high voltage experiments that I have done in the past.
Old May 20, 2009 | 06:11 PM
superduty4x4
LOL, yeah I spent about 5 minutes screwing around with a mirror and gave up. 3 bolts and 10 minutes later, PCM was out
Old May 20, 2009 | 07:47 PM
PaysonPSD's Avatar
PaysonPSD
Chase,
We all know you just couldn't figure it out backwards in the mirror.
Old May 21, 2009 | 09:22 AM
superduty4x4
Originally Posted by PaysonPSD
Chase,
Hey now, just because I was born in ID doesn't mean I just fell off a tater truck. I work for the gov't, I like to do things the hard way no matter what
Old May 21, 2009 | 09:41 AM
PaysonPSD's Avatar
PaysonPSD
Now that's a funny line.
If the PCM has been changed the label on connector may be wrong.
Pulling PCM to be sure is the best way.
Old May 21, 2009 | 10:13 AM
superduty4x4
No sense in trying to hide from the truth... in the words of Popeye, I yam what I yam
I thought the sticker was on the PCM connector itself, not on the wiring plug under the hood? I should know this...
Old May 21, 2009 | 03:59 PM
tjc transport's Avatar
tjc transport
i ain't rite
ya mean like the time you put the capacitor to your tongue to see if it was charged??
oh shoot! i wasn't supposed to mention that to anyone, huh??
Old May 21, 2009 | 04:17 PM
big poppa's Avatar
big poppa
Chase, what did you do??, lol...
Old May 21, 2009 | 04:22 PM
superduty4x4
I think that was directed at Jim. I've never done anything like that! Unless you count putting a 9v battery on your tongue
Old May 21, 2009 | 05:07 PM
megawatt00's Avatar
megawatt00
LOL I have chsrged a few of then up and handed them to helpers contact end first.
You maniac
