Clutch problem
Old Jul 2, 2002 | 04:55 PM
1990350's Avatar
1990350
Clutch problem
I have a 1990 F-350 with a 460 and a 4 speed. The problem I'm having is that when the clutch is engaged there is a squeak in the clutch. I think it's the throw out bearing, because I looked in the housing and could not see any space between the pressure plate fingers and the bearing. Should there be some clearance there? I should add that when I go under the truck when it's running and put just the slightest amount of pressure on the clutch fork, in any direction the squeak stops, and also when the clutch is disengaged the squeak stops. I can find no way to adjust the slave cylinder. Any advice would be helpful.
Thanks
Ken
Old Jul 3, 2002 | 11:42 PM
1ole4d's Avatar
1ole4d
Clutch problem
Ok...first of all there is no way to adjust the hydraulic clutches. They're self-adjusting. Secondly...if the squealing or squeaking stops when you play with the throwout bearing than 99.9% of the time that's your culprit. Just a word of advice from personal experience, if you replace the throwout bearing you might want to replace the clutch slave cylinder also while you have the tranny separated. Just a helpfull hint Hope this helps some.
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old Jul 5, 2002 | 01:37 AM
bigredford04's Avatar
bigredford04
Clutch problem
Try just bleeding the system before you get into taking the tranny out. Simple solutions sometimes works. Could just be that old fluid isnt letting the TOB engage right.
Texas A&M Off-Road
`95 F150 4x4 5.0
33" BFG KMs
Old Jul 5, 2002 | 01:58 AM
Boss_358's Avatar
Boss_358
Clutch problem
Scratcher
Jun 9, 2016 07:56 PM
mfp4073
1983 - 2012 Ranger & B-Series
16
Nov 30, 2012 07:22 PM
Rob04
Nov 2, 2006 01:46 PM
CrazySpyder69
26
Jul 16, 2006 03:04 PM
plapczynski
Jun 2, 2005 02:45 PM
