drivetrain lube
Old Apr 19, 2002 | 11:00 AM
redtopper's Avatar
redtopper
drivetrain lube
i have a 96 150 4x4. i.m putting new seal in tcase and resealing the rear differential. what kinds on fluids do i use, gear lube or ATF?
and how much?
oh ya, how do i tell if its a slip or fixed yoke tcase
have 8.8 rear adn 1356 manual shift tcase.
thanx
redtopper
Old Apr 19, 2002 | 12:17 PM
rabidranger's Avatar
rabidranger
drivetrain lube
Not sure what to tell ya about the fluids, but a slip yoke will "slip" (slide) out of the back of the t-case along a splined shaft. The fixed yoke will have to be unbolted to be removed, or it may even be held in the t-case via some snap rings that would require a t-case rebuild to get to.
Old Apr 19, 2002 | 03:37 PM
aerocolorado's Avatar
aerocolorado
drivetrain lube
Most T-cases use ATF while the diff uses hypoid gear oil. Check your owner's manual, it will tell you type and capacity required.
Old Jul 9, 2002 | 04:57 PM
Brian460's Avatar
Brian460
drivetrain lube
Your transfer case uses ATF, put gear lube in the rear end.
Old Jul 9, 2002 | 05:19 PM
Brian460's Avatar
Brian460
drivetrain lube
BWD444
Offroad & 4x4
Jan 2, 2017 01:19 PM
No704
Jun 3, 2016 02:33 PM
whomrig
1997 - 2003 F150
May 29, 2016 09:55 PM
Fordman96
1978 - 1996 Big Bronco
Oct 15, 2011 03:19 PM
82f1504x4
Offroad & 4x4
27
Dec 3, 2004 02:14 PM
