1978 - 1996 Big Bronco
Quick T-case question
Old Oct 13, 2011 | 02:28 PM
Fordman96's Avatar
Fordman96
Got a 96' Bronco XLT 351W E4OD Transmission. 3.88 rear axle D44 front axle... what t-case do i have?
Old Oct 13, 2011 | 02:51 PM
Conanski's Avatar
Conanski
Should be a BW 1356.
Old Oct 13, 2011 | 07:18 PM
greystreak92's Avatar
greystreak92
Ditto to what Paul said but the axle gearing is not an OEM ratio so, unless you have swapped them, someone has made changes to the driveline and there is no guarantee the T-case is still the OEM unit.
Old Oct 15, 2011 | 08:08 AM
Fordman96's Avatar
Fordman96
IDK why i said 3.88, i meant to say Ford 8.8" im way out of it for some reason.
Old Oct 15, 2011 | 03:19 PM
greystreak92
Ah then its more than likely the T-case is indeed the Borg-Warner 1356 unit.
RonRooster
May 17, 2010 10:59 AM
17fordguy
1966 - 1977 Early Broncos
Oct 24, 2009 03:41 AM
2classics
Aug 11, 2007 10:34 PM
mikeb2
Aug 3, 2005 11:56 AM
