Drivers side window switch
Old May 19, 2009 | 06:45 PM
pepito113's Avatar
pepito113
Over the last 2-3 months I have noticed that the drivers side window switch has been giving me problems. You lower the window and when you push the bottom for the window to come up nothing happens. Then I push it multiple times until it finally goes. No other switch has this problem. Has anyone heard about this or have any ideas on how to fix without getting a new one?
Old May 19, 2009 | 06:53 PM
Horse Doctor's Avatar
Horse Doctor
It is not difficult to change the switch. I suppose you could clean the contacts, etc. on the one you have which might help, but you have to get at the switch so I would replace it.
Old May 19, 2009 | 08:27 PM
stronger's Avatar
stronger
very common. I've put 2 in '05s. $60 from ford.
Old May 20, 2009 | 04:50 AM
svt2205's Avatar
svt2205
As they've said, it's very common. I've removed mine to clean up the contacts 3 times. Each time it works for a few month and then becomes intermittent.
Did Ford change the contact design or material? I'm guessing the replacement will be just as bad.
Old May 20, 2009 | 10:21 AM
tooldad's Avatar
tooldad
Apparently common from other posts I have seen. Had mine replaced under warranty ~1-1/2 - 2 year ago. No problem since.
Old May 20, 2009 | 11:41 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Pepito113, send me your vin and I'll send you the part number for the switch for your truck. Dan.
Old May 20, 2009 | 01:09 PM
V8EXPLR's Avatar
V8EXPLR
Yup, seems very common, as I had the same question about 6 months back about my '06 Screw. All window swtiches from the drivers door worked fine, except for the passenger rear had the same hit or miss issues yours does now. Had the swtich replaced under warranty and all has been fine since. (knock on wood).
Old May 20, 2009 | 09:45 PM
pepito113's Avatar
pepito113
So I went by the dealer today to get the switch changed. Service guy told me there were to other trucks in for the same problem. Switch got changed and all is well for now. Dan (y2k) thanks for the offer and time.
Old May 21, 2009 | 01:24 AM
nlfireblade's Avatar
nlfireblade
Do you have to take the inside door skin off to get at the switches or just the door handle that the switches are in? My drivers window is acting up again. Can you get at the contacts to clean them easily? I'm wondering why they corrode so quickly and maybe a dab of dielectric grease will help solve the problem?
Old May 21, 2009 | 05:34 AM
svt2205's Avatar
svt2205
Check your PM. I'm need a new switch
Old May 21, 2009 | 05:36 AM
svt2205's Avatar
svt2205
Just remove the panel the switches are in. They don't corrode or that's what I've noticed on mine. There is a black carbon layer that is building up and preventing electrical contact. Plus with each time the switch arcs, a small amount of the contact material melts and is displaced. The switch will eventually need to be replaced.
Old May 21, 2009 | 02:55 PM
Parts Guy Wyatt
Former Vendor
Pepito113, You're welcome. I'm here to help as much as I can. Dan.
svt2205, I got your message and sent you a reply. Dan.
Old May 21, 2009 | 05:40 PM
llcool's Avatar
llcool
Is it covered under warranty if it is still within the warranty period? Mine is acting up also and I have a few thousand KM to go.
Old May 21, 2009 | 05:47 PM
nlfireblade
Panel? You mean the door 'handle', right?
I wonder why other vehicles don't seem to have this problem so often. There are a few truck models where this is a common occurrence but it doesn't seem to be an issue for most vehicles.
Old May 22, 2009 | 09:16 AM
V8EXPLR's Avatar
V8EXPLR
Yes it's covered under the basic 3yr/36K mile warranty. As stated before by myself and many others, we've had ours swapped for free under warranty.
From what I've read, it's due to the design of the window switches and door handle panel. Again just what I've read from other users outside this thread and on other forums, is moisture (rain, melted snow, etc) makes its way into the switch panel. Of course others state it's the design on the contacts. Who knows for sure, maybe it's both of the above. Either way, it's a design flaw that Ford should look into. Wonder exactly how many of these they've replaced under warranty, as well as outside the warranty period. Seems to be a mjor issue on every site I frequent.
