I'm a bonehead!
Old May 19, 2009 | 04:05 PM
  #31
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by gtnwood
Pardon the tiny hijack,
You mean to tell me install isn't as simple as removing the 2 tiny bolts from the pcm under the drivers side dash and pulling it from there and removing the cover to install the tuner
Have a look at this vid. click here
Old May 19, 2009 | 04:17 PM
  #32
superduty4x4's Avatar
superduty4x4
That's a good vid. The one extra bolt under the hood isn't much more trouble... slightly a pain to get at but once you figure out the right way to bend yourself its cake.
Old May 19, 2009 | 04:20 PM
  #33
gtnwood's Avatar
gtnwood
Thank you Sir
One friend told me I had to "remove the drivers side front wheel and the fender skirt and pull some bolt", and another told me "no you dont just pull it from under the dash"
Old May 19, 2009 | 04:28 PM
  #34
miller_feed
Thank you Sir
Now you know the rest of the story.
Old May 19, 2009 | 04:55 PM
  #35
superduty4x4
You have to move the inner fender to get to the IDM, but not the PCM. Maybe that's what your friend was thinking.
Old May 19, 2009 | 07:22 PM
  #36
mndiesel's Avatar
mndiesel
Originally Posted by DieselCamper01
Even when your just a spectator?
How about dropping the magnet, thats why I have TWO
Old May 19, 2009 | 08:53 PM
  #37
dvani's Avatar
dvani
OK I am officially screwed. The socket is in the idler pulley based on the belt layout on the radiator support. I pulled the fan loose and tried to loosen the bolts on the pulley.... no way they are moving.
Any other ideas?
Old May 19, 2009 | 09:12 PM
  #38
dvani's Avatar
dvani
I was wrong... its the water pump.
Old May 19, 2009 | 10:55 PM
  #39
dvani's Avatar
dvani
Kudo's to 12ozd,
Got an air compressor ?
If so , blow air behind / under the pulley.
May move it so you can get it.
A combination of compressed air and my long flex magnet did the trick after a couple of hours getting the socket set exactly in the center of the pulley.
mdoug3
Aerostar
Aug 9, 2012 02:44 PM
69ford99
2004 - 2008 F150
Apr 5, 2010 10:49 PM
stxchck13
Dec 15, 2009 03:44 PM
cartmanea
Dec 31, 2007 10:57 AM
CruiserClass
Mar 1, 2007 12:57 AM
