trans. cooler advice needed
Old May 19, 2009 | 11:34 AM
mtford's Avatar
mtford
2000 f350 psd pulling 6000 lbs. if you look at my last two threads trans. went at 75k. in the shop being rebuilt. used my wife's 2002 psd excursion to pull the same trailer up the same hill, on a 70 degree day. both trucks have synthetic fluid in them. this truck has the trans. temp. idiot gauge on cluster. At the 5 mile marke guage started climbing off center mark where it normaly is and by the 8 mile mark of a 10 mile climb I had to pull off and let cool down. Another 50 yrds. and it would have been out of the normal range and through the yellow into the red. so...... I'm thinking I need to drop this job on the mountain and beef up both truck trans. cooling abilities. Should i add a cooler to the system? Or replace the exsisting cooler with a bigger unit? I like the idea of less connections for lesser chance of petential leaks. What cooler is the best bang for the buck? Is the later modle 6.0 liter trans cooler the way to go? Thanks in advance for all the good help you guys provide.
Old May 19, 2009 | 11:37 AM
superduty4x4's Avatar
superduty4x4
The 6.0 cooler is a great option, WAY bigger than stock. I got one from a wrecked truck for $40. You just remove the stock cooler and drop the 6.0 in its place. There are also tons of aftermarket coolers out there if you want to go that route (cheaper for a new aftermarket than a new 6.0L cooler).
BTW, don't trust the factory "idiot light" trans temp gauge. By the time it shows any significant temp change the damage is likely already done. Check out this link.
Old May 19, 2009 | 11:39 AM
mtford's Avatar
mtford
was the 6.0 a direct bolt in and how much bigger/ thicker was it?
Old May 19, 2009 | 11:42 AM
mtford's Avatar
mtford
Pure Diesel Power is selling the 6.0 liter cooler for $229.00
Old May 19, 2009 | 11:43 AM
superduty4x4
The 6.0 is almost a direct bolt in. The 7.3 uses 3/8" trans lines and the 6.0 uses 1/2", so you need some 1/2" trans rated hose and a couple of adapter fittings. You also need either longer bolts for the bottom 2 mounts, or a fender washer and remove the rubber grommets to get the bolts to fit. I'll see if I can find a pic, but the 6.0 cooler is about 3x as big as the OEM. There are 2 versions of the 6.0 cooler too- 26 row and 31 row. I have the 26 row waiting to go in, I helped a friend install a 31 row in his. Either one is plenty big enough, and I hear that the 26 row gives you a bit more room down low for routing the 1/2" hose without worrying about kinking it.
Old May 19, 2009 | 11:45 AM
triskit16's Avatar
triskit16
Check ebay 1st. Ive seen a couple on there but got snatched up pretty quickly. The plumbing of the lines and the shear size of the unit is the only thing different. Easily adapted though.
Edit: Im slow...
superduty4x4
Pic showing the 26 row compared to stock:
Old May 19, 2009 | 11:48 AM
mtford's Avatar
mtford
the one pure diesel has for sale is the earlier one!! Not the nice big one you have pictured.
Old May 19, 2009 | 11:50 AM
superduty4x4
Another good photo, comparing 6.0 stock to 7.3 stock and V10 stock:
Old May 19, 2009 | 11:52 AM
mtford's Avatar
mtford
Ford dealer in New England has ebay listing for $369.00 plus s&h. No salvage yards in my area carry this late model stuff sadly.
Old May 19, 2009 | 11:55 AM
superduty4x4
Contact Ed, the FTE parts guy. He has better pricing than that. He'll probably chime in shortly.
Old May 19, 2009 | 12:01 PM
mtford's Avatar
mtford
Thanks for the help sd4x4. How can i reach ed?
Old May 19, 2009 | 12:05 PM
superduty4x4
His user name is FTE/PARTS-GUY, usually when someone types in the name Ed it turns blue and you can click on it.
Ed's Website
26 row 6.0 cooler from Ed
31 row 6.0 cooler from Ed
Old May 19, 2009 | 12:07 PM
triskit16's Avatar
triskit16
Th!nkPartsGuy/FTEPartsGuy
Click that and it should take you straight to the porduct on Ed's site!
Dangit! I guess Im not fully awake yet...slow once again!
Old May 19, 2009 | 12:09 PM
superduty4x4
Nope, I'm just more of a post "lady of the night" (PC to avoid the word sensor ) than you are!
