5.4 motor question
Old May 19, 2009 | 06:54 AM
dl117's Avatar
dl117
5.4 motor question
I resently granaded the 5.4 in my 1999 f250 ld and found a good deal on a 2005 5.4 with 65,000 on it. I was wondering if anyone here knew if everything would work...ie sensors, computer and such, or was there changes that would make it a pain in the butt.
thanks
Old May 19, 2009 | 07:47 AM
l-m tech's Avatar
l-m tech
The three valve wont interchange without heavy mods like a wiring harnessfor the engine and trans ,and a pcm.you will also have a check engine light for the lack of a turbine shaft sensor on your trans.
Old May 19, 2009 | 02:30 PM
dl117's Avatar
dl117
What motor years would interchange? I am a Chevy convert and still learning the Ford.
thanks
Old May 19, 2009 | 05:55 PM
galaxie641's Avatar
galaxie641
You want '99-'03 F150/Expedition or '00-'04 Superduty. the Sd engines may require you to use your old intake and/or a few sensors. Personally I'd even stay away from '99s as it just wasn't a great year.
Old May 26, 2009 | 02:41 PM
pjhayseed's Avatar
pjhayseed
follow-up question
Hi - I'm new to this site and Fords...so I'm going to hijack a thread right off the bat, but for good reason. I have the same issue...I inherited a '98 Expedition with a bad 5.4 engine. I have the opportunity to pick up an '05 5.4 that comes with all the accessories, wiring harness, computer, etc. Are you saying that this swap shouldn't even be attempted? Is it too much of a hassle with computer issues? I would really like get some more info before I make the decision on the '05 engine.
THANKS!
Xx0573
Modular V8 (4.6L, 5.4L)
Jul 3, 2013 11:32 PM
514stang
2004 - 2008 F150
Aug 8, 2009 09:13 PM
TPDK97
Mar 28, 2007 10:42 AM
Maine5.4L
Engine Swaps
Jan 20, 2006 10:08 AM
BlueZack
Nov 29, 2004 02:18 PM
