460 has a left front lifter tick
Old May 18, 2009 | 09:56 PM
Econoline 150's Avatar
Econoline 150
I picked up a 76 Ford F350 with a 460. It runs well, has pretty low miles but the left front lifter is tapping. The truck sat alot.
Anyone have any advo on this 460 ? I was thinking of changing the oil often with some Delo 400 diesel oil, which has alot of detergents and change it often maybe its clogged ? I'd rather not put much money or time in it for now. Open to suggestions !
Old May 19, 2009 | 12:31 AM
gthbryce's Avatar
gthbryce
Try using thicker oil.
Old May 19, 2009 | 08:45 AM
Econoline 150
Guy told me he went with 10W-40, 20w-40 might help I guess. The Delo 400 diesel oil is 15W-40 but I havent done that yet.
Old May 19, 2009 | 10:50 AM
C-Leigh Racing's Avatar
C-Leigh Racing
Heavier the oil is harder it is for the oil pump to push it, now, think what the dizzy gear & that pump shaft got to go through trying to push that heavy oil.
I never even thought about it myself untill I tryed to prime the engine with a shaft & drill. Wasnt but a second or two that drill started smoking & far as I know its a regular OEM pump.
More than likely you either have a rocker arm or the fulcrum it rides on worn & maybe a bent push rod because the rockers are non adjustable bolt down type.
I know it would be a bugger pulling that valve cover off, but sounds like what needs to be done to find out for sure.
Neil
Old Jun 11, 2009 | 11:45 AM
Econoline 150
Neil
Thought I'd update this, I ended up replacing a pushrod and now it's quiet and up for sale.
JAMES1952
May 23, 2015 02:24 AM
2002fx4122
79
Jan 14, 2013 07:08 PM
kgarcia
Sep 27, 2010 05:16 PM
460k&n
2004 - 2008 F150
Apr 18, 2010 09:17 PM
zaaac
Jan 31, 2010 02:55 PM
