drivers side window issues.
Old May 18, 2009 | 08:59 PM
jqcj5's Avatar
jqcj5
I've got a 1999 f350 crew cab 7.3l single rear wheel.
My drivers side window finally stopped working. It has been hit or miss for a few months now. I used to able to tap on the switch and get it working. It has the auto down function. I can hear a clicking sound under the dash but it won't budge up or down.
I checked the wires in the door behind the door panel and in the rubber boot you can see when the doors is open and everying looks good, at least none are cracked or separated. I've also checked the fuses under the hood and in the cab and none are blown. While I had the door panel off I tapped on the window motor just in case it was bound up.
What could it be? The switch or the motor? Since I hear clicking under the dash when hitting the switch, does that mean that the switch is working?
Thanks
Old May 18, 2009 | 09:55 PM
shark1979's Avatar
shark1979
mine would go down real slow. and some times stop midway ,wait a few min. then it would go the rest of they way, i fixed mine by cleaning the window track, and gave it a shot of silcone spray.
Old May 19, 2009 | 01:49 AM
ron's power stroke's Avatar
ron's power stroke
check the wires going though the boot from the door to the door post..i had this happen and it was a broken wire...
Old May 19, 2009 | 07:47 AM
Calli's Avatar
Calli
I'll throw in my standard answer. Moisture get in the drive motor. Spraying with WD-40 works for a time, then needs replacement.
Old May 19, 2009 | 08:45 AM
DieselCamper01's Avatar
DieselCamper01
Probably the switch itself. There is a mod for fixing this. Someone with a link will chime in.
poppop50
Jan 7, 2021 09:14 PM
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
flossie
1997 - 2003 F150
Oct 29, 2014 05:38 PM
lightningdan
May 15, 2014 11:04 AM
mikren
1997 - 2003 F150
28
Aug 22, 2009 09:39 AM
