Clutch for M5OD
Old Jul 10, 2002 | 10:33 AM
Ford Truck Racer's Avatar
Ford Truck Racer
Clutch for M5OD
Looking at a replacement clutch and here's what have in mind to be used on a Hays 30lb steel flywheel. Either a Centraforce II, Centraforce dual friction, or a hays comp clutch.
Anyone have any recommendations. Want one for daily driving, towing, and some offroading. thank for any suggestions.
Old Jul 10, 2002 | 05:57 PM
mr clutch's Avatar
mr clutch
Clutch for M5OD
I custom build performance clutches for domestic and imports. Give me a call if you are interested. 888-462-2739
Old Jul 11, 2002 | 03:33 AM
bigredford04's Avatar
bigredford04
Clutch for M5OD
Go w/ an LUK clutch. I got mine thru a tranny shop but i've heard pep boys sells 'em. It is MUCH better than the Centerforce I i had in there before, a lot more holding power and grabs like a champ.
Texas A&M Off-Road
`95 F150 4x4 5.0
33" BFG KMs
Old Jul 11, 2002 | 10:40 PM
Ford Truck Racer
Clutch for M5OD
Also one thing I would like to consider is that I might be getting a ZF tranny soon. Do they both use the same clutch for the 302, or at least the same pressure plate and flywheel. Also what price range should I be looking at. Plan on high power rebuild and going in with motor so it will be a while till I decide, thanks for any info.
Old Jul 12, 2002 | 02:58 AM
bigredford04
Clutch for M5OD
hahaha...you work on imports...lol
j/k...nice plug
Texas A&M Off-Road
`95 F150 4x4 5.0
33" BFG KMs
Old Jul 15, 2002 | 02:49 PM
Ford Truck Racer
Clutch for M5OD
Just wondering is the M5OD and the ZF clutches the same or is it different clutch plate. May consider going to a ZF
Old Jul 15, 2002 | 03:42 PM
lanero's Avatar
lanero
Clutch for M5OD
I think all of the cluthes and preassure plates are the same (except for diameter). I went from a Mazda M5OD to a NP435 and only had to change the throw out bearing. And that was because it went from an internal to an external slave.
Roger Lane
Old Jul 15, 2002 | 03:44 PM
bigredford04
Clutch for M5OD
alumcanTandThd
1978 - 1996 Big Bronco
Nov 4, 2016 10:42 AM
Inline66
15
May 27, 2016 01:41 PM
LostFade
2004 - 2008 F150
Jul 4, 2015 09:34 PM
RRranch
Jan 14, 2010 11:41 AM
Fordyman
Mar 13, 2009 04:52 PM
