Recommendations for a Quality Throwout Bearing?
I recently replaced the clutch/flywheel on my 66 F100 240 3.03. I used the AC Delco 381101 kit and the throwout bearing was immediately noisy. At first it was noisy whenever the clutch was disengaged, but that went away. Now it's been about 1500 miles and it screeches right at the point wear the clutch grabs while engaging, but only does this when the truck is cold-- maybe the first 1 or 2 shifts. From what I've read, this means the throwout could soon fail. So, I'm looking for a high quality replacement. The best looking option I've found so far is the Hays 70230, which is a self aligning bearing that is supposed to fit my truck. Any opinions on this or other TO bearings?
Need a Ford part #, betcha they were used for a bunch of applications? Gotta be plenty out there sitting on shelves. Maybe even in your hometown even.
Most bearings have an industry number stamped on them, and can be used to cross reference. Try calling Green Sales, or NOSpartsltd, maybe they can help.
http://www.gizmology.net/bearings.htm
(452! pages)
http://www.skf.com/binary/79-66347/457013.pdf
(452! pages)
Here's an update on this-- I suspected a leak from the transmission input seal might also have been causing my squeaking noise (especially since it was just the first few shifts). I did replace the pilot bearing and rear main seal when I did the clutch. I pulled the transmission, replaced the throwout with the part I mentioned above, and found no leak from the transmission. But, I've got a pretty good leak from the oil pan gasket. From the service manual it looks like that could get into the bellhousing where the oil pan meets the bearing cover.
I got the trans back in and aligned properly. I used a combination of 6" bolts with the heads cut off as a guide (had to take the top 2 out when it got close to give it a little play), keeping the clutch disengaged with a piece of 2x2 wedged on the pedal, and playing with the angle of the engine with a floor jack just in front of the bellhousing. Once the angle was right, it slid right in the last 2 inches.
The results are great, no more noise from the throwout or screeching when shifting, vibrations from 2000-2500 rpm are gone, and shifts are waaay smoother. I almost don't have to think about what my feet are doing now. It was getting to be a chore before. So, I don't think the leak was the culprit. But I got the oil pan gasket and found the right gasket for the oil pickup tube and I'll be taking care of that next.
Sorry, I should have taken some. I'm no expert, still figuring things out I go. It's a pretty messy job, and kind of a pita with jack stands and a creeper, but there's nothing magical or scary in there. Just have to take your time and do it right. I'd be happy to talk you through it if you ever have to try it.
I think the real issue was that I didn't get the transmission aligned right the first time. I used the mounting bolts to force it the last couple inches. I think that caused the shifting symptoms and quickly wore out the throwout bearing.
Join the club. I did something similar installing an engine. I can't remember exactly what happened but the just of it was I didn't have the release lever in the right place as the engine slipped into the bell housing. Everything tightened down fine but boogered a finger on the pressure plate...dag gummit.
Edit: As my memory comes back, it did not tighten down fine and that's how I found it. But the damage had already been done.
